kernel 2.6.32
Toni
Slackware: slackware-14
Kernel: 3.10.5
Desktop: i3
kernel 2.6.32
Messaggio da Toni »
ciao , dando un occhio su
http://kernelnewbies.org/LinuxChanges
1.8. Easy local kernel configuration
Most people uses the kernel shipped by distros - and that's good. But some people like to compile their own kernels from kernel.org, or maybe they like following the Linux development and want to try it. Configuring your own kernel, however, has become a very difficult and tedious task - there're too many options, and some times userspace software will stop working if you don't enable some key option. You can use a standard distro .config file, but it takes too many time to compile all the options it enables.
To make easier the process of configuration, a new build target has been added: make localmodconfig. It runs "lsmod" to find all the modules loaded on the current running system. It will read all the Makefiles to map which CONFIG enables a module. It will read the Kconfig files to find the dependencies and selects that may be needed to support a CONFIG. Finally, it reads the .config file and removes any module "=m" that is not needed to enable the currently loaded modules. With this tool, you can strip a distro .config of all the unuseful drivers that are not needed in our machine, and it will take much less time to build the kernel. There's an additional "make localyesconfig" target, in case you don't want to use modules and/or initrds.
qualcosa di eccezionale :lol: ,
in pratica carichiamo un kernel di wolkerding huge, poi make localmodconfig , e si ottiene un kernel e i moduli minimi indispensabili , certo bisognorebbe collegare tutto quello che utilizziamo part-time ( pen drive , webcam , hardware plug & play in genere).
e poi è presente la risposta di Molnar allo scheduler BFS di Colivas
1.5. CFQ low latency mode
Recommended LWN commentary from Jens Axboe
In this release, the CFQ IO scheduler (the one used by default) gets a new feature that greatly helps to reduce the impact that a writer can have on the system interactiveness. The end result is that the desktop experience should be less impacted by background IO activity, but it can cause noticeable performance issues, so people who only cares about throughput (ie, servers) can try to turn it off echoing 0 to /sys/class/block/<device name>/queue/iosched/low_latency. It's worth mentioning that the 'low_latency' setting defaults to on.
Code: (commit), (commit)
UPDATE :
scusate penso sia più produttivo caricare un kernel generic di un kernel huge , visto che il nuovo target di make va a leggere lsmod.
metrofox
Kernel: 3.4.4-ck3
Desktop: FluxBox-1.3.1
Re: kernel 2.6.32
Messaggio da metrofox »
Questa feature è eccezionale. :)
gigiobagiano
Nome Cognome: Filippo
Kernel: vanilla-4.4.38
Distribuzione: SalixOS
Re: kernel 2.6.32
Messaggio da gigiobagiano »
Sembra che a kolivas copino sempre qualcosa... [-X
Interessante il nuovo comando appena ho tempo provo... ;)
Re: kernel 2.6.32
Interessante davvero.
Certo, come ha detto Toni, bisogna dopo dare una ripassata per controllare se
qualche modulo attualmente non caricato non ci possa servire in seguito...
Blallo
Nome Cognome: Savino Liguori
Slackware: 14.2 / 12.2
Kernel: 4.4.14-smp
Desktop: DWM
Re: kernel 2.6.32
Messaggio da Blallo »
e il modo per non metterli come moduli, ma statici sarebbe make localesconfig? (da quello che leggo, ma chiedo per conferma)
Paoletta
Slackware: 14.2 - 64 bit
Desktop: fluxbox
Re: kernel 2.6.32
Messaggio da Paoletta »
jimmy_page_89 ha scritto:e il modo per non metterli come moduli, ma statici sarebbe make localesconfig? (da quello che leggo, ma chiedo per conferma)
yes...davvero comoda la cosa (anche se bisogna comunque collegare tutto quello che non utilizziamo sempre)
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
Re: kernel 2.6.32
perlomeno lo attacchi solo una volta e non ci pensi più..anche perchè puoi sempre ritoccare a mano dopo se manca qualcosa no?
Mario Vanoni
Nome Cognome: Mario Vanoni
Kernel: 3.0.4 statico
Desktop: fluxbox/seamonkey
Re: kernel 2.6.32
Messaggio da Mario Vanoni »
Ho messo su due macchine 2.6.32,
usando il vecchio .config e make oldconfig,
rispondendo sempre NO alle domande,
eccetto quella del processore usato,
kernel puramente statico, tutto al 100% OK.
La terza segue quando finisce il test in corso,
probabilmente domani.
Bart
Re: kernel 2.6.32
Messaggio da Bart »
Fantastica questa feature. Grazie per la segnalazione. :thumbright:
Non mi è molto chiaro il punto "1.5. CFQ low latency mode" evidenziato da Toni.
DarthSteve
Nome Cognome: Stefano
Slackware: --Current--
Kernel: 6.9..x
Re: kernel 2.6.32
Messaggio da DarthSteve »
Allora... ho compilato il kernel... e provato le nuove -features-
e sembra, per ora, funzionare come specificato ...
ma ho un 'piccolo' effetto collaterale che e; il seguente:
Con il comando 'halt' or 'shutdown -h now' (da console)
il computer e il monitor rimangono accesi !?!
- Cosa ho sbagliato ?
- TIA!
--- The Jedi Code ---
There is no emotion; there is peace.
There is no ignorance; there is knowledge.
There is no passion; there is serenity.
There is no death; there is the Force
Bart
Re: kernel 2.6.32
Messaggio da Bart »
DarthSteve ha scritto:Allora... ho compilato il kernel... e provato le nuove -features-
- TIA!
Hai provato con localmodconfig o localyesconfig?
Mario Vanoni
Re: kernel 2.6.32
Bart ha scritto:Fantastica questa feature. Grazie per la segnalazione. :thumbright:
make menuconfig
Processor type and features --->
Preemption Model (No Forced Preemption (Server)) ---> (la mia scelta !!!)
scegli
( ) Preemptible Kernel (Low-Latency Desktop)
http://lwn.net/Articles/355987/
What the 'low_latency' knob does
Posted Oct 8, 2009 7:11 UTC (Thu) by axboe (subscriber, #904)
Parent article: The CFQ "low latency" mode
The description of the 'low_latency' mode isn't very accurate unfortunately, perhaps Jon didn't have his coffee before reading over it :-). Let me attempt to rectify that.
The low_latency knob doesn't impact delays or merging, one of the key aspects to getting low latency for a series of operations (like starting your firefox while other IO is happening) is actually making sure we get the delays right. If we take the classic case of reader vs writer, the writer dirty speed will greatly outnumber the writeback speed. So we always have tons of dirty pages waiting to be written. The normal reader, however, does dependent reads that are serialized by each other. When one read finishes, another will be issued by the reader very shortly. Achieving good throughput and latency for the reader in CFQ is accomplished by briefly waiting for another IO when one has completed. In CFQ, this is called idling.
The two primary changes in behaviour for CFQ in -rc3 is letting seeky IO also idle, even if the hardware does command queuing (which most does these days) and limiting the damage that the async IO can do while sync IO is also happening. With the 'low_latency' knob switched to on, CFQ will only slowly build up a queue depth of async writes. This greatly helps reduce the impact that a writer will have on the system interactiveness, since when we miss a sync idle window only slightly, the amount of async writeback sent to the device will be limited by the time since that last sync IO.
The end result is that the desktop experience should be less impacted by background IO activity. It's also worth mentioning that the 'low_latency' setting defaults to on.
Blallo
Kernel: 4.4.14-smp
Desktop: DWM
Re: kernel 2.6.32
mio dio
è lentissimo e mi causa addirittura problemi in xfce non so come sia possibile ma sembra che xfce non lavori più con dbus
infatti wicd non si avvia più, il vassoio di sistema ora va ora non va e non fa più l'automount
con tutto il rispetto, ma che schifo
Mario Vanoni
Re: kernel 2.6.32
jimmy_page_89 ha scritto:mio dio
Per me 2.6.32, vedi profilo, funziona benissimo,
aggiornato oggi al 2.6.32-bfs311, no problems.
Piccola differenza con te, non uso automatismi ...
metrofox
Kernel: 3.4.4-ck3
Re: kernel 2.6.32
Nessun problema nemmeno col mio kernel 2.6.32, strano.
