Qualcuno sta tentando di accedere alla mia Slackware!
anycolouryoulike
Kernel: 2.6.34.8
Desktop: KDE 3.5.10
Messaggioda anycolouryoulike » sab set 15, 2007 23:56
Grazie a Conky ho appena visto dal /var/log/messages che qualcuno sta tentando di accedere al mio sistema via SSH! :shock:
Sep 15 23:45:00 darkstar sshd[19718]: Did not receive identification string from 121.117.161.47
Sep 15 23:47:16 darkstar sshd[20721]: Failed password for root from 121.117.161.47 port 49903 ssh2
Sep 15 23:47:20 darkstar sshd[20756]: Failed password for root from 121.117.161.47 port 50002 ssh2
Sep 15 23:47:26 darkstar sshd[20786]: Invalid user apple from 121.117.161.47
Sep 15 23:47:26 darkstar sshd[20786]: Failed password for invalid user apple from 121.117.161.47 port 50081 ssh2
Sep 15 23:47:30 darkstar sshd[20825]: Failed password for root from 121.117.161.47 port 50169 ssh2
Sep 15 23:47:33 darkstar sshd[20908]: Invalid user brian from 121.117.161.47
Sep 15 23:47:33 darkstar sshd[20908]: Failed password for invalid user brian from 121.117.161.47 port 50223 ssh2
Sep 15 23:47:37 darkstar sshd[20931]: Failed password for root from 121.117.161.47 port 50283 ssh2
Sep 15 23:47:45 darkstar sshd[20958]: Invalid user andrew from 121.117.161.47
Sep 15 23:47:45 darkstar sshd[20958]: Failed password for invalid user andrew from 121.117.161.47 port 50348 ssh2
Sep 15 23:47:49 darkstar sshd[21013]: Failed password for root from 121.117.161.47 port 50451 ssh2
Sep 15 23:47:52 darkstar sshd[21040]: Invalid user newsroom from 121.117.161.47
Sep 15 23:47:52 darkstar sshd[21040]: Failed password for invalid user newsroom from 121.117.161.47 port 50515 ssh2
Sep 15 23:47:56 darkstar sshd[21065]: Failed password for root from 121.117.161.47 port 50568 ssh2
Sep 15 23:48:11 darkstar sshd[21086]: Invalid user magazine from 121.117.161.47
Sep 15 23:48:11 darkstar sshd[21086]: Failed password for invalid user magazine from 121.117.161.47 port 50624 ssh2
Cosa devo fare? Devo preoccuparmi?
lamarozzo
Linux 2.6
Linux 2.6
Distribuzione: archlinux
Messaggioda lamarozzo » dom set 16, 2007 0:33
whois mi ha dato
netnum: 121.112.0.0 - 121.119.255.255
netname: OCN
descr: NTT Communications Corporation
descr: 1-6 Uchisaiwai-cho 1-chome Chiyoda-ku, Tokyo 100-8019 Japan
country: JP
admin-c: JNIC1-AP
tech-c: JNIC1-AP
status: ALLOCATED PORTABLE
remarks: Email address for spam or abuse complaints :abuse@ocn.ad.jp
mnt-by: MAINT-JPNIC
mnt-lower: MAINT-JPNIC
remarks: -+-+-+-+-+-+-+-+-+-+-+-++-+-+-+-+-+-+-+-+-+-+-+-+-+-+
remarks: This object can only be updated by APNIC hostmasters.
remarks: To update this object, please contact APNIC
remarks: hostmasters and include your organisation's account
remarks: name in the subject line.
changed: hm-changed@apnic.net 20060707
source: APNIC
role: Japan Network Information Center
address: Kokusai-Kougyou-Kanda Bldg 6F, 2-3-4 Uchi-Kanda
address: Chiyoda-ku, Tokyo 101-0047, Japan
country: JP
phone: +81-3-5297-2311
fax-no: +81-3-5297-2312
e-mail: hostmaster@nic.ad.jp
admin-c: JI13-AP
tech-c: JE53-AP
nic-hdl: JNIC1-AP
mnt-by: MAINT-JPNIC
changed: hm-changed@apnic.net 20041222
changed: hm-changed@apnic.net 20050324
changed: ip-apnic@nic.ad.jp 20051027
source: APNIC
inetnum: 121.112.0.0 - 121.119.170.255
netname: PLALA
descr: Plala Networks Inc.
country: JP
admin-c: SA3783JP
tech-c: SA3783JP
remarks: This information has been partially mirrored by APNIC from
remarks: JPNIC. To obtain more specific information, please use the
remarks: JPNIC WHOIS Gateway at
remarks: http://www.nic.ad.jp/en/db/whois/en-gateway.html or
remarks: whois.nic.ad.jp for WHOIS client. (The WHOIS client
remarks: defaults to Japanese output, use the /e switch for English
remarks: output)
changed: apnic-ftp@nic.ad.jp 20060725
changed: apnic-ftp@nic.ad.jp 20061023
source: JPNIC
C'è anche un'indirizzo email per segnalare abusi o cose simili: abuse@ocn.ad.jp
Purtroppo non sono un esperto di sicurezza informatica, ma visto che hanno provato ad accedere come root io farei rifiutare al demone sshd le connessioni come root. Se gli attacchi insistono con iptables imposti poi una regola che escluda completamente l'indirizzo da cui provengono gli attacchi.
cacao74
Linux 1.0
Linux 1.0
Kernel: 2.6.37.6
Desktop: fluxbox
Messaggioda cacao74 » dom set 16, 2007 0:38
Beh.. si, dovresti preoccuparti.
In rete circolano script kiddies ed altra robaccia...
Qualched'uno sta facendo qualche tentativo sulla porta 22 del tuo IP pubblico.
Hai diverse soluzioni per limitare o arginare definitivamente il problema:
- utilizza password robuste e complesse
- cambi porta per quel servizio
- disabiliti completamente il servizio
- limiti l'uso del servizio solo da particolari IP (tcp_wrapper/iptables)
- limiti l'accesso permettendo solo l'uso di chiavi disabilitando l'autenticazione con password
- ecc...
Trova la combinazione migliore per le tue esigenze.
ciao
kasher
Linux 2.0
Linux 2.0
Kernel: 2.6.27.7
Desktop: kde 3.5.10
Messaggioda kasher » dom set 16, 2007 2:06
quoto cacao74, senò potresti utilizzare una soluzione più elegante, il port knocking in modo da aprire la porta solamente all' evenienza.
kasher.
Dani
Desktop: gnome
Distribuzione: arch
Messaggioda Dani » dom set 16, 2007 2:07
Se usi password non vulnerabili ad attacchi di tipo dizionario non mi preoccuperei piu' di tanto...
simplex
Linux 2.4
Linux 2.4
Messaggioda simplex » dom set 16, 2007 8:54
Pero' e' sempre una seccatura che riempie i log...
Ora ho l'autenticazione tramite chiavi, prima per limitare il bruteforce sulla 22 usavo questa regola sul firewall (pf openbsd)
pass in on $ext_if inet proto tcp from any to ($ext_if) port ssh \
   keep state \
   (max-src-conn-rate 2/60, overload <bastards> flush global)
Praticamente mette in blacklist chi tenta due o piu' connnessioni in meno di 60 secondi (ho isdn), la tabella viene flushata ogni ora.
Purtroppo non so come si faccia con iptables..
slucky
Slackware: 14.1
Kernel: 4.11.3-smp
Desktop: xfce4
Distribuzione: freeBSD-11.1
Messaggioda slucky » dom set 16, 2007 9:21
Ciao, ti basta disabilitare l'accesso da root a ssh, se non amministri pc in remoto, questo è caldamente consigliato farlo ;)
Ti basta editare il file /etc/ssh/sshd_config e dove leggi:
# Authentication:
#LoginGraceTime 2m
#PermitRootLogin yes
metti:
# Authentication:
#LoginGraceTime 2m
#PermitRootLogin no
Ora sei a posto.
Ciao :D
cacao74
Linux 1.0
Linux 1.0
Kernel: 2.6.37.6
Desktop: fluxbox
Messaggioda cacao74 » dom set 16, 2007 9:21
simplex ha scritto:Pero' e' sempre una seccatura che riempie i log...
Controlla, dalla pagina di manuale di iptables, la descrizione del modulo "limit" per ottenere un comportamento simile a "pf". In rete dovresti trovare anche materiale molto descrittivo.
Anche il consiglio di utilizzare "port knoking" e' molto valido!
ciao
cacao74
Linux 1.0
Linux 1.0
Kernel: 2.6.37.6
Desktop: fluxbox
Messaggioda cacao74 » dom set 16, 2007 9:23
slucky ha scritto:
# Authentication:
#LoginGraceTime 2m
#PermitRootLogin no
Ora sei a posto.
Ciao :D
Forse e' meglio decommentare se si vuole attivare una "feature" altrimenti rimane
attiva la parametrizzazione predefinita. ;-)
ciao
slucky
Slackware: 14.1
Kernel: 4.11.3-smp
Desktop: xfce4
Messaggioda slucky » dom set 16, 2007 9:34
Certo ssh resta attivo, si dovrebbe proprio disabilitarlo completamente come servizio per stopparlo............però per quanto riguarda il login da root, test di Rkhunter :
* Check: SSH
Searching for sshd_config...
Found /etc/ssh/sshd_config
Checking for allowed root login... [ OK (Remote root login disabled) ]
Quindi non è necessario decommentare ;)
Saluti a tutti :D
cacao74
Linux 1.0
Linux 1.0
Kernel: 2.6.37.6
Desktop: fluxbox
Messaggioda cacao74 » dom set 16, 2007 9:57
slucky ha scritto:Quindi non è necessario decommentare ;)
mmm... non mi hai convinto! :-)
cito il man di sshd_config
DESCRIPTION
sshd(8) reads configuration data from /etc/ssh/sshd_config (or the file
specified with -f on the command line). The file contains keyword-argu-
ment pairs, one per line. Lines starting with '#' and empty lines are
interpreted as comments.
Arguments may optionally be enclosed in double
quotes (") in order to represent arguments containing spaces.
PermitRootLogin
Specifies whether root can log in using ssh(1). The argument
must be ``yes'', ``without-password'', ``forced-commands-only'',
or ``no''. The default is ``yes''.
ciao!
slucky
Slackware: 14.1
Kernel: 4.11.3-smp
Desktop: xfce4
Messaggioda slucky » dom set 16, 2007 10:10
Beh, polemica sterile, così la disabilitazione funziona.............poi ognuno faccia come crede, son fatti suoi alla fine................
Risaluti a tutti
:lol:
anycolouryoulike
Kernel: 2.6.34.8
Desktop: KDE 3.5.10
Messaggioda anycolouryoulike » dom set 16, 2007 11:40
A me se non decommento la linea il login di root rimane abilitato, decommentandola invece non accetta la password anche se è giusta, quindi presumo che sia disabilitato, quindi quoto cacao74.
Non ho capito perché provano intrusioni di questo tipo: è impossibile indovinare l'user e la password!
j0kers
Linux 2.4
Linux 2.4
Slackware: 13
Kernel: 2.6.32
Desktop: xfce4
Messaggioda j0kers » dom set 16, 2007 12:13
Esistono vari script che ti fanno il brute della password inoltre esistono svariati exploit che sfuttano i bug dei demoni di sistema e per sshd ce ne sono a bizzeffe (ovviamente non tutte le versioni sshd sono buggate) 8) 8) 8)
cacao74
Linux 1.0
Linux 1.0
Kernel: 2.6.37.6
Desktop: fluxbox
Messaggioda cacao74 » dom set 16, 2007 12:13
anycolouryoulike ha scritto:Non ho capito perché provano intrusioni di questo tipo: è impossibile indovinare l'user e la password!
Non e' proprio impossibile... sicuramente e' piu' facile tentare un accesso con il login di "root", ma essendo script automatizzati utilizzano grossi dizionari di accout e password e.. a loro il tempo non manca! ;-)
ciao
Torna a “Sicurezza”
Chi c’è in linea
Visitano il forum: Nessuno e 2 ospiti
