Uploader php
Ansa89
Slackware: 14.2 64bit
Kernel: 4.9.61
Desktop: XFCE 4.12
Uploader php
Messaggioda Ansa89 » mar giu 15, 2010 10:50
Sto cercando di scrivere un uploader php con un po' di difficoltà.
<?php
$up_path = "upload";
echo '<html>
        <title>Upload file</title>
        <body>';
function num_upload() {
        echo '<form action="upload.php" method="post">
                How many images do you want to upload?
                <input type="text" name="num">
                <input type="submit" value="Submit">
                </form>';
function multi_upload($num) {
        echo '<form action="upload.php" enctype="multipart/form-data" method="post">
                <table border="0" width="400" cellspacing="0" cellpadding="0" align=center>';
        for ($i = 1; $i <= $num; $i++) {
                echo '<tr><td>'."Image ".$i.": ".'</td>
                        <td><input type="file" name="image[]"></td></tr>
                        <tr><td>'."Desc. ".'</td>
                        <td><input type="text" name="desc[]"></td></tr>';
        echo '<tr><td colspan=2 align=center>
                <input type=submit value="Add Image(s)"></td></tr>
                </table></form>';
function upload($up_path) {
        $j = 1;
        while (list($key,$value) = each($_FILES['image']['name'])) {
                print "1\n";
                //list($desc_k,$desc_v) = each($_REQUEST['desc']['name']);
                echo "2\n";
                if (! empty($value)) {
                        echo $value."\n";
                        $filename = $value;
                        $filename = str_replace(" ","_",$filename);
                        $filename = str_replace("'","",$filename);
                        echo $filename."\n";
                        $path = $up_path."/".$filename;
                        if (file_exists($path)) {
                                echo "The file ".$filename." already exists.\n";
                                break;
                        echo $path."\n";
                        if (copy($_FILES['image']['tmp_name'][$key],$path))
                                echo "File ".$j." caricato\n";
                        else {
                                echo "Errore nella copia";
                        if (chmod($path,0660))
                                echo "File ".$j." chmod'd\n";
                        if (! empty($desc[$j])) {
                                $desc_file = fopen("$path/.pics_desc","a");
                                $imgdesc = $desc_v;
                                $imgdesc = str_replace("\n"," ",$imgdesc);
                                $write = $filename.";".$desc_v."\n";
                                fwrite($desc_file,$write);
                                fclose();
                        $j++;
num_upload();
if (! empty($_REQUEST['num'])) {
        echo'<br /><p>';
        multi_upload($_REQUEST['num']);
        echo '</p>';
if (! empty($_FILES['image'])) {
        echo $_FILES['image']."\n";
        echo '<br /><p>';
        upload($up_path);
        echo '</p>';
echo '</body></html>';
1) Perché quando uso "\n" con echo, non va a capo?
2) Per ché dentro la funzione "upload()" non posso usare la variabile "$up_path" che ho dichiarato inizialmente?
3) Perché non funziona, dicendomi "PHP Warning: copy() [<a href='function.copy'>function.copy</a>]: Filename cannot be empty in /var/www/htdocs/upload.php on line 49, referer: http://192.168.7.4/upload.php" (preso dal log di apache)? In pratica è come se nella "copy()" la variabile "$path" (che uso come path di destinazione, comprensivo del nome file) fosse vuota; peccato che la faccio stampare la riga prima e sono sicuro che ha il valore giusto :roll: .
j0kers
Slackware: 13
Kernel: 2.6.32
Desktop: xfce4
Re: Uploader php
Messaggioda j0kers » mar giu 15, 2010 11:38
Scusa dove non ti funziona lo "\n" qui:
                print "1\n";
                echo "2\n";
o qui
Per la seconda prova a modificare in questo modo:
 echo $filename , "\n";
Per quanto riguarda la variabile prova in questo modo:
$up_path = upload;
Senza apici, per il resto attendiamo pareri di esperti 8)
Ultima modifica di j0kers il mar giu 15, 2010 11:48, modificato 1 volta in totale.
Re: Uploader php
Messaggioda conraid » mar giu 15, 2010 11:43
@jokers, non sono esperto, ma... cancella il post è meglio ;-)
- o usi il punto o la virgola per unire le stringhe, non entrambi
- se non metti tra apici o virgolette una stringhe per il sistema è altro (una costante in questo caso) e darà errore o un warning dicendo che prenderà il valore upload come costante (ma non è quello che vuole ansa)
@ansa
1) gli a capo sono <br> in html
2) come non puoi usarla? in che senso? se intendi usarla senza metterla tra le variabili passate alla funzione, allora "globalizzala"
3) esiste la directory upload dentro il path in cui gira lo script?
Ansa89
Kernel: 4.9.61
Desktop: XFCE 4.12
Re: Uploader php
Messaggioda Ansa89 » mar giu 15, 2010 11:49
L'errore del "\n" me lo dà ovunque indistintamente.
Se provo a cambiare in
echo $filename. , "\n";
Mi dà errore sulla virgola e si blocca.
Se uso "$up_path = upload;" senza apici o virgolette, non me lo prende e quando vado a stampare il valore di "$path" ottengo "/image.jpg" invece di "upload/image.jpg", quindi non va bene neanche quello.
j0kers
Slackware: 13
Kernel: 2.6.32
Desktop: xfce4
Re: Uploader php
Messaggioda j0kers » mar giu 15, 2010 11:52
Mi da questo errore:
Warning: copy(upload/481698140.jpg) [function.copy]: failed to open stream: No such file or directory
la directory upload non esiste. comunque usa $up_path = 'upload';
Ansa89
Kernel: 4.9.61
Desktop: XFCE 4.12
Re: Uploader php
Messaggioda Ansa89 » mar giu 15, 2010 11:56
conraid ha scritto:1) gli a capo sono <br> in html
1) Ma come faccia a mettere un "a capo" dentro un file?
Come faccio a modificare un "a capo" della descrizione con uno spazio?
2) Proverò a metterla globale.
3) La directory esiste e ha i permessi giusti, il problema è che la funzione "copy()" dice che la destinazione (cioè il secondo parametro) è vuoto :? .
j0kers
Slackware: 13
Kernel: 2.6.32
Desktop: xfce4
Re: Uploader php
Messaggioda j0kers » mar giu 15, 2010 12:08
Uploaded with ImageShack.us
Ansa89
Kernel: 4.9.61
Desktop: XFCE 4.12
Re: Uploader php
Messaggioda Ansa89 » mar giu 15, 2010 12:11
Prova a caricare un file con degli spazi.
j0kers
Slackware: 13
Kernel: 2.6.32
Desktop: xfce4
Re: Uploader php
Messaggioda j0kers » mar giu 15, 2010 12:15
Ho dotuto creare la directory upload manualmente altrimenti non funzionava.
Ansa89
Kernel: 4.9.61
Desktop: XFCE 4.12
Re: Uploader php
Messaggioda Ansa89 » mar giu 15, 2010 12:31
j0kers ha scritto:Ho dotuto creare la directory upload manualmente altrimenti non funzionava.
Quello è normale.
Prova a caricare dei file "grossi" (intorno ai 10MB).
Paoletta
Slackware: 14.2 - 64 bit
Desktop: fluxbox
Re: Uploader php
Messaggioda Paoletta » mar giu 15, 2010 12:33
ciao ansa89, per il primo dei problemi devi lasciar perdere "\n" ed usare "<br />" al suo posto; infatti per visualizzare l'output del programma stai usando un browser e questi capiscono solo il codice html; per cui "a capo" è "<br />". Se invece tu avessi scritto il testo di una mail e poi l'avessi inviato con il comando mail() di php, allora per andare a capo dovresti usare "\n" (a meno di non voler usare codice html anche per il testo della mail); per gli altri problemi ora guardo
Re: Uploader php
Messaggioda targzeta » mar giu 15, 2010 12:38
In realtà il codice è HTML e quindi "a capo" si traduce con "<BR>", il "\n" funziona uguale ma vale per il sorgente del file generato (prova a visualizzare il sorgente della pagina).
2) Si chiama "scope delle variabili" hai una variabile esterna alla funzione che si chiama $up_path e un parametro della funzione con lo stesso nome, la funzione ovviamente vede il parametro.
3) Quando passia via GET o POST dei nomi dei file o dei path in generale ti conviene sempre codificarli e poi decodificarli, quello che ho notato io è che spesso i parametri vengono modificati (ad esempio ' ' viene sostituito da '_' se non ricordo male).
Linux Registered User #454438
20/04/2013 - Io volevo Rodotà
j0kers
Slackware: 13
Kernel: 2.6.32
Desktop: xfce4
Re: Uploader php
Messaggioda j0kers » mar giu 15, 2010 12:43
Con file grossi (11MB) mi ritorna alla posizione iniziale senza nessun messaggio e nessuna copia in upload
Re: Uploader php
Messaggioda targzeta » mar giu 15, 2010 12:47
4) C'è un limite alla dimensione dei file che puoi caricare. Guarda il file php.ini e cerca qualcosa come "post_max_size" o "upload_max_filesize"
:edit: Vedi qui per capire meglio la differenza.
j0kers
Slackware: 13
Kernel: 2.6.32
Desktop: xfce4
Re: Uploader php
Messaggioda j0kers » mar giu 15, 2010 12:57
50M
