Creare un firewall
darkstaring
Linux 2.6
Linux 2.6
Creare un firewall
Messaggioda darkstaring » gio dic 02, 2010 15:44
Olà, stavo dando un'occhiata al Wiki di Alien ed ho trovato il generatore di
Firewall http://connie.slackware.com/~alien/efg/...
Volevo sapere se è ottimizabile, ho notato molte cose commentate..Questo è il sorgente:
#!/bin/sh
# Generated iptables firewall script for the Linux 2.4 kernel and later.
# Script generated by Easy Firewall Generator for IPTables 1.15
# copyright 2002 Timothy Scott Morizot
# Modified for Slackware Linux by Eric Hameleers <alien@slackware.com>
# This generator is adapted from the original to work on Slackware Linux.
# Basically, I corrected the path name to the iptables* commands
# and re-wrote this comment.
# It can be executed with the typical start and stop arguments.
# If used with stop, it will stop after flushing the firewall.
# The save and restore arguments will save or restore the rules
# from the /etc/sysconfig/iptables file.  The save and restore
# arguments are included to preserve compatibility with
# Redhat's or Fedora's init.d script if you prefer to use it.
# You may want to save this script as /etc/rc.d/rc.firewall
# and make it executable, like this:
#   chmod +x /etc/rc.d/rc.firewall
# Slackware Linux will then automatically run this script
# with the "start" parameter.
# Local Settings
# sysctl location.  If set, it will use sysctl to adjust the kernel parameters.
# If this is set to the empty string (or is unset), the use of sysctl
# is disabled.
SYSCTL="/sbin/sysctl -w"
# To echo the value directly to the /proc file instead
# SYSCTL=""
# IPTables Location - adjust if needed
IPT="/usr/sbin/iptables"
IPTS="/usr/sbin/iptables-save"
IPTR="/usr/sbin/iptables-restore"
# Internet Interface
INET_IFACE="wlan0"
# Localhost Interface
LO_IFACE="lo"
LO_IP="127.0.0.1"
# Save and Restore arguments handled here
if [ "$1" = "save" ]
then
   echo -n "Saving firewall to /etc/sysconfig/iptables ... "
   $IPTS > /etc/sysconfig/iptables
   echo "done"
   exit 0
elif [ "$1" = "restore" ]
then
   echo -n "Restoring firewall from /etc/sysconfig/iptables ... "
   $IPTR < /etc/sysconfig/iptables
   echo "done"
   exit 0
fi
# Load Modules
echo "Loading kernel modules ..."
# You should uncomment the line below and run it the first time just to
# ensure all kernel module dependencies are OK.  There is no need to run
# every time, however.
# /sbin/depmod -a
# Unless you have kernel module auto-loading disabled, you should not
# need to manually load each of these modules.  Other than ip_tables,
# ip_conntrack, and some of the optional modules, I've left these
# commented by default.  Uncomment if you have any problems or if
# you have disabled module autoload.  Note that some modules must
# be loaded by another kernel module.
# core netfilter module
/sbin/modprobe ip_tables
# the stateful connection tracking module
/sbin/modprobe ip_conntrack
# filter table module
# /sbin/modprobe iptable_filter
# mangle table module
# /sbin/modprobe iptable_mangle
# nat table module
# /sbin/modprobe iptable_nat
# LOG target module
# /sbin/modprobe ipt_LOG
# This is used to limit the number of packets per sec/min/hr
# /sbin/modprobe ipt_limit
# masquerade target module
# /sbin/modprobe ipt_MASQUERADE
# filter using owner as part of the match
# /sbin/modprobe ipt_owner
# REJECT target drops the packet and returns an ICMP response.
# The response is configurable.  By default, connection refused.
# /sbin/modprobe ipt_REJECT
# This target allows packets to be marked in the mangle table
# /sbin/modprobe ipt_mark
# This target affects the TCP MSS
# /sbin/modprobe ipt_tcpmss
# This match allows multiple ports instead of a single port or range
# /sbin/modprobe multiport
# This match checks against the TCP flags
# /sbin/modprobe ipt_state
# This match catches packets with invalid flags
# /sbin/modprobe ipt_unclean
# The ftp nat module is required for non-PASV ftp support
/sbin/modprobe ip_nat_ftp
# the module for full ftp connection tracking
/sbin/modprobe ip_conntrack_ftp
# the module for full irc connection tracking
/sbin/modprobe ip_conntrack_irc
# Kernel Parameter Configuration
# See http://ipsysctl-tutorial.frozentux.net/chunkyhtml/index.html
# for a detailed tutorial on sysctl and the various settings
# available.
# Required to enable IPv4 forwarding.
# Redhat users can try setting FORWARD_IPV4 in /etc/sysconfig/network to true
# Alternatively, it can be set in /etc/sysctl.conf
#if [ "$SYSCTL" = "" ]
#then
#    echo "1" > /proc/sys/net/ipv4/ip_forward
#else
#    $SYSCTL net.ipv4.ip_forward="1"
#fi
# This enables dynamic address hacking.
# This may help if you have a dynamic IP address \(e.g. slip, ppp, dhcp\).
#then
#    echo "1" > /proc/sys/net/ipv4/ip_dynaddr
#else
#    $SYSCTL net.ipv4.ip_dynaddr="1"
#fi
# This enables SYN flood protection.
# The SYN cookies activation allows your system to accept an unlimited
# number of TCP connections while still trying to give reasonable
# service during a denial of service attack.
then
    echo "1" > /proc/sys/net/ipv4/tcp_syncookies
else
    $SYSCTL net.ipv4.tcp_syncookies="1"
fi
# This enables source validation by reversed path according to RFC1812.
# In other words, did the response packet originate from the same interface
# through which the source packet was sent?  It's recommended for single-homed
# systems and routers on stub networks.  Since those are the configurations
# this firewall is designed to support, I turn it on by default.
# Turn it off if you use multiple NICs connected to the same network.
then
    echo "1" > /proc/sys/net/ipv4/conf/all/rp_filter
else
    $SYSCTL net.ipv4.conf.all.rp_filter="1"
fi
# This option allows a subnet to be firewalled with a single IP address.
# It's used to build a DMZ.  Since that's not a focus of this firewall
# script, it's not enabled by default, but is included for reference.
# See: http://www.sjdjweis.com/linux/proxyarp/
#then
#    echo "1" > /proc/sys/net/ipv4/conf/all/proxy_arp
#else
#    $SYSCTL net.ipv4.conf.all.proxy_arp="1"
#fi
# The following kernel settings were suggested by Alex Weeks. Thanks!
# This kernel parameter instructs the kernel to ignore all ICMP
# echo requests sent to the broadcast address.  This prevents
# a number of smurfs and similar DoS nasty attacks.
then
    echo "1" > /proc/sys/net/ipv4/icmp_echo_ignore_broadcasts
else
    $SYSCTL net.ipv4.icmp_echo_ignore_broadcasts="1"
fi
# This option can be used to accept or refuse source routed
# packets.  It is usually on by default, but is generally
# considered a security risk.  This option turns it off.
then
    echo "0" > /proc/sys/net/ipv4/conf/all/accept_source_route
else
    $SYSCTL net.ipv4.conf.all.accept_source_route="0"
fi
# This option can disable ICMP redirects.  ICMP redirects
# are generally considered a security risk and shouldn't be
# needed by most systems using this generator.
#then
#    echo "0" > /proc/sys/net/ipv4/conf/all/accept_redirects
#else
#    $SYSCTL net.ipv4.conf.all.accept_redirects="0"
#fi
# However, we'll ensure the secure_redirects option is on instead.
# This option accepts only from gateways in the default gateways list.
then
    echo "1" > /proc/sys/net/ipv4/conf/all/secure_redirects
else
    $SYSCTL net.ipv4.conf.all.secure_redirects="1"
fi
# This option logs packets from impossible addresses.
then
    echo "1" > /proc/sys/net/ipv4/conf/all/log_martians
else
    $SYSCTL net.ipv4.conf.all.log_martians="1"
fi
# Flush Any Existing Rules or Chains
echo "Flushing Tables ..."
# Reset Default Policies
$IPT -P INPUT ACCEPT
$IPT -P FORWARD ACCEPT
$IPT -P OUTPUT ACCEPT
$IPT -t nat -P PREROUTING ACCEPT
$IPT -t nat -P POSTROUTING ACCEPT
$IPT -t nat -P OUTPUT ACCEPT
$IPT -t mangle -P PREROUTING ACCEPT
$IPT -t mangle -P OUTPUT ACCEPT
# Flush all rules
$IPT -F
$IPT -t nat -F
$IPT -t mangle -F
# Erase all non-default chains
$IPT -X
$IPT -t nat -X
$IPT -t mangle -X
if [ "$1" = "stop" ]
then
   echo "Firewall completely flushed!  Now running with no firewall."
   exit 0
fi
E se sia possibile aggiungere la porta ethernet così:
INET_IFACE="wlan0" "eth0"
o così
INET_IFACE="wlan0 eth0"
Grazieee
Ultima modifica di darkstaring il sab dic 04, 2010 2:13, modificato 1 volta in totale.
krisis
Distribuzione: debian
Re: Easy Firewall AlienBob
Messaggioda krisis » gio dic 02, 2010 15:59
Non l'ho letto tutto ma mi pare tagliato su misura per una sola scheda di rete , per tanto :
INET_IFACE="ethX"
è il valore corretto , dove X è l'id relativo alla tua interfaccia ethernet.
darkstaring
Linux 2.6
Linux 2.6
Messaggioda darkstaring » gio dic 02, 2010 22:55
E se voglio usare più periferiche? devo ricopiare il tutto ed aggiungere INET_IFACE2="eth0" e anche tutti i rispettivi INET_IFACE?
krisis
Messaggioda krisis » ven dic 03, 2010 9:58
Se devi fare un firewall per gestire più periferiche devi studiarti iptables e farti il tuo script su misura.
darkstaring
Linux 2.6
Linux 2.6
Messaggioda darkstaring » sab dic 04, 2010 2:12
Ho dato un'occhiata a wikipedia, ma non saprei cosa acettare e cosa no...
Una bella guida???... magari in italiano
Thank's
hashbang
Nome Cognome: Luca De Pandis
Distribuzione: Win 10 Pro | macOS
Messaggioda hashbang » sab dic 04, 2010 8:51
darkstaring ha scritto:Ho dato un'occhiata a wikipedia, ma non saprei cosa acettare e cosa no...
Thank's
Sito ufficiale
Ubuntu-it wiki
Inoltre, appena Loris aggiorna il repository x86, troverai gtk-iptables che è un frontend grafico scritto in gtk+.
There's a certain kind of programmer who'll look at any problem and say, 'I know, I will use XML.' Now he has two problems.
Stack is the new term for "I have no idea what I'm actually using". [Erich Schubert]
albatross
Linux 1.0
Linux 1.0
Re: Creare un firewall
Messaggioda albatross » sab feb 05, 2011 22:57
un bel po di tempo fa ne abbiamo discusso qui [url]http://www.slacky.eu/forum/viewtopic.php?f=2&t=165&hilit=albatross[/url] con useless
DarthSteve
Linux 2.0
Linux 2.0
Nome Cognome: Stefano
Slackware: --Current--
Kernel: 4.9
Messaggioda DarthSteve » dom feb 06, 2011 10:27
Messaggio da darkstaring » 12/02/2010, 10:55 pm
Puoi usare, eg.:
# External Interface
EXT_IF="eth0 wlan0"
for IF in ${EXT_IF} ; do
     iptables -A INPUT -i ${IF} -p all -m state --state INVALID -j DROP
     ..etc...
 done
or in alternativa:
for IF in eth0 wlan0 ; do
done
- C'e un tutorial di Oskar Andreasson (in inglese) al URL http://www.frozentux.net/documents/iptables-tutorial/
che include alcuni esempi di configurazione per diverse tipologie di firewall.
--- The Jedi Code ---
There is no emotion; there is peace.
There is no ignorance; there is knowledge.
There is no passion; there is serenity.
There is no death; there is the Force
marlavo
Linux 2.0
Linux 2.0
Nome Cognome: Marco Lavorini
Slackware: 14.2 01 00 00 00
Kernel: 4.4.88
Desktop: XFCE 4.12
Messaggioda marlavo » dom feb 06, 2011 11:42
Oppure, se non ti interessa studiare iptables ma semplicemente vuoi creare un firewall, uno tool che secondo me è molto interessante è Firewall Builder:
http://www.slacky.eu/aadm/pkgs/index.php?ver=14&pkg=1884
Io l'ho usato per creare un semplice firewall sulla connessione Internet con modem (chiavetta), ma sicuramente fwbuilder ti consente di creare firewall per reti assai più complesse, con il vantaggio di avere un'interfaccia grafica che ti permette di capire "al volo" cosa fa il firewall. Il bello è che alla fine crea uno script che altro non fa che usare iptables, quindi se il risultato non ti soddisfa puoi sempre modificare questo script.
Spero di esserti stato di aiuto.
boh
Slackware: 14.2 (x64)
Kernel: 4.4.19
Desktop: KDE 4.14.21
Messaggioda boh » dom feb 06, 2011 12:15
Una guida che potrebbe esserti utile la trovi a questo indirizzo (è in inglese): http://www.thegeekstuff.com/2011/01/ipt ... damentals/
leocata
Linux 2.6
Linux 2.6
Desktop: xfce 4.x
Messaggioda leocata » mar feb 08, 2011 10:21
Il problema del firewall me lo sono sempre posto... ma obbiettivamente non ho avuto molto tempo per studiarmi IPtables e quindi da utonto (hihihi) ho preso il file presente in /etc/ppp/firewall-standalone e l'ho modificato cambiando solo una riga (quella in grassetto)... e l'ho copiato in /etc/rc.d/rc.firewall dando ovviamente i seguenti permessi -rwxr-xr-x Avrò fatto bene ??? boh? ma da una prima lettura mi sembra sufficiente.
#!/bin/sh
# firewall-standalone   This script sets up firewall rules for a standalone
#                       machine
# Copyright (C) 2005 Roaring Penguin Software Inc.  This software may
# be distributed under the terms of the GNU General Public License, version
# 2 or any later version.
# LIC: GPL
echo "lancio il firewall"
# Interface to Internet
[b]EXTIF=wlan0[/b]
iptables -P INPUT ACCEPT
iptables -P OUTPUT ACCEPT
iptables -P FORWARD DROP
iptables -F FORWARD
iptables -F INPUT
iptables -F OUTPUT
# Deny TCP and UDP packets to privileged ports
iptables -A INPUT -p udp -i $EXTIF --dport 0:1023 -j LOG
iptables -A INPUT -p tcp -i $EXTIF --dport 0:1023 -j LOG
iptables -A INPUT -p udp -i $EXTIF --dport 0:1023 -j DROP
iptables -A INPUT -p tcp -i $EXTIF --dport 0:1023 -j DROP
# Deny TCP connection attempts
iptables -A INPUT -i $EXTIF -p tcp --syn -j LOG
iptables -A INPUT -i $EXTIF -p tcp --syn -j DROP
# Deny ICMP echo-requests
iptables -A INPUT -i $EXTIF -p icmp --icmp-type echo-request -j DROP
albatross
Linux 1.0
Linux 1.0
Messaggioda albatross » mar feb 08, 2011 11:49
@leocata
quale è il compito di questo firewall?
Dimmi che cosa devi proteggere e quali esigenze di connessione hai.
C'è un'incongruenza tra i comandi -P e - F che hai dato
-P definisce il comportamento predefinito per quella catena mentre -F azzera tutte le regole per quella catena. In pratica con -F hai annullato i comandi dati nelle righe precedenti...
notsafe
Linux 2.4
Linux 2.4
Messaggioda notsafe » mar feb 08, 2011 12:24
albatross ha scritto:C'è un'incongruenza tra i comandi -P e - F che hai dato
in realtà -F (flush) elimina tutte le rules nella catena,non cambia la policy impostata in precedenza.
miklos
Slackware: 14.1 64bit
Kernel: 3.16.3
Desktop: openbox 3.5.2
Messaggioda miklos » mar feb 08, 2011 13:03
Un bel po' di tempo fa diedi un'occhiata a questo qui, molto potente e anche in versione lite.
Ti consente di scrivere regole in modo piu' "umano" che poi lui a runtime converte in comandi iptables.
Non ho controllato qui, ma su SlackBuilds trovi come farti il pacchetto
Comunque se il firewall non ha "grandi" pretese, anche io ti consiglio di studiare iptables, o sistemare quello che hai trovato come ti spiegava DarthSteve.
leocata
Linux 2.6
Linux 2.6
Desktop: xfce 4.x
Messaggioda leocata » mar feb 08, 2011 13:07
Premesso che questi settaggi sono presenti in qualsiasi slakware nel file presente in /etc/ppp/fi**** detto questo, le righe stabiliscono
le politiche INPUT-OUTPUT-FORWARD DEFAULT
e poi il resto è commentato... tuttavia ripeto l'avevo preso per buono, perchè presente di default e poi ho letto:
# machine
