seguendo questa guida http://www.slackers.it/configurare-le-schede-di-rete-in-slackware/ sto cercando di configurare una rete wi-fi; ho una chiavetta D-LINK DWL-G122 Rev. C1.
Se provo con rc.inet1 wlan0_start ricevo questi errori :
Error for wireless request "Set nickname" (8B1C) :
SET failed on device wlan0 ; Operation not supported.
Polling for DHCP server on interface wlan0:
dhcpcd: versione 5.2.2 starting
dhcpcd: wlan0: waiting for carrier
dhcpcd: timed out
dhcpcd: allowing 8 seconds for IPv4ALL timeout
dhcpcd: timed out
ifconfig da questo output :
eth0 Link encap:Ethernet HWaddr 00:18:f3:60:04:f4
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:27
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:20 errors:0 dropped:0 overruns:0 frame:0
TX packets:20 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1000 (1000.0 B) TX bytes:1000 (1000.0 B)
wlan0 Link encap:Ethernet HWaddr 00:1e:58:9e:65:81
Mentre iwconfig :
wlan0 IEEE 802.11bg ESSID:"Default"
Mode:Managed Access Point: Not-Associated Tx-Power=20 dBm
Retry long limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:on
Questo è il file rc.inet1.conf :
# /etc/rc.d/rc.inet1.conf
# This file contains the configuration settings for network interfaces.
# If USE_DHCP[interface] is set to "yes", this overrides any other settings.
# If you don't have an interface, leave the settings null ("").
# You can configure network interfaces other than eth0,eth1... by setting
# IFNAME[interface] to the interface's name. If IFNAME[interface] is unset
# or empty, it is assumed you're configuring eth<interface>.
# Several other parameters are available, the end of this file contains a
# comprehensive set of examples.
# Config information for eth0:
IPADDR[0]=""
NETMASK[0]=""
USE_DHCP[0]="yes"
DHCP_HOSTNAME[0]=""
# Config information for eth1:
IPADDR[1]=""
NETMASK[1]=""
USE_DHCP[1]=""
DHCP_HOSTNAME[1]=""
# Config information for eth2:
IPADDR[2]=""
NETMASK[2]=""
USE_DHCP[2]=""
DHCP_HOSTNAME[2]=""
# Config information for eth3:
IPADDR[3]=""
NETMASK[3]=""
USE_DHCP[3]=""
DHCP_HOSTNAME[3]=""
# Default gateway IP address:
GATEWAY=""
# Change this to "yes" for debugging output to stdout. Unfortunately,
# /sbin/hotplug seems to disable stdout so you'll only see debugging output
# when rc.inet1 is called directly.
DEBUG_ETH_UP="no"
## Example config information for wlan0. Uncomment the lines you need and fill
## in your info. (You may not need all of these for your wireless network)
IFNAME[4]="wlan0"
IPADDR[4]=""
NETMASK[4]=""
USE_DHCP[4]="yes"
DHCP_HOSTNAME[4]="icculus-wireless"
DHCP_KEEPRESOLV[4]="yes"
DHCP_KEEPNTP[4]="yes"
DHCP_KEEPGW[4]="yes"
DHCP_IPADDR[4]=""
WLAN_ESSID[4]="Default"
WLAN_MODE[4]=Managed
WLAN_RATE[4]="54M auto"
WLAN_CHANNEL[4]="auto"
##WLAN_KEY[4]="D5AD1F04ACF048EC2D0B1C80C7"
##WLAN_IWPRIV[4]="set AuthMode=WPAPSK | set EncrypType=TKIP | set WPAPSK=95389dc66eaf7e6efd5b5523ae33d7925bf4df2f8b6099495592d44a774fea16"
WLAN_WPA[4]="wpa_supplicant"
WLAN_WPADRIVER[4]="wext"
WLAN_WPADRIVER[4]="/etc/wpa_supplicant.conf"
## Some examples of additional network parameters that you can use.
## Config information for wlan0:
#IFNAME[4]="wlan0" # Use a different interface name nstead of
# the default 'eth4'
#HWADDR[4]="00:01:23:45:67:89" # Overrule the card's hardware MAC address
#MTU[4]="" # The default MTU is 1500, but you might need
# 1360 when you use NAT'ed IPSec traffic.
#DHCP_KEEPRESOLV[4]="yes" # If you dont want /etc/resolv.conf overwritten
#DHCP_KEEPNTP[4]="yes" # If you don't want ntp.conf overwritten
#DHCP_KEEPGW[4]="yes" # If you don't want the DHCP server to change
# your default gateway
#DHCP_IPADDR[4]="" # Request a specific IP address from the DHCP
# server
#WLAN_ESSID[4]=DARKSTAR # Here, you can override _any_ parameter
# defined in rc.wireless.conf, by prepending
# 'WLAN_' to the parameter's name. Useful for
# those with multiple wireless interfaces.
#WLAN_IWPRIV[4]="set AuthMode=WPAPSK | set EncrypType=TKIP | set WPAPSK=thekey"
# Some drivers require a private ioctl to be
# set through the iwpriv command. If more than
# one is required, you can place them in the
# IWPRIV parameter (separated with the pipe (|)
# character, see the example).
wpa_supplicant.conf :
# See /usr/doc/wpa_supplicant-0.6.10/wpa_supplicant.conf.sample
# for many more options that you can use in this file.
# This line enables the use of wpa_cli which is used by rc.wireless
# if possible (to check for successful association)
ctrl_interface=/var/run/wpa_supplicant
# By default, only root (group 0) may use wpa_cli
ctrl_interface_group=0
eapol_version=1
ap_scan=1
fast_reauth=1
#country=US
# WPA protected network, supply your own ESSID and WPAPSK here:
network={
scan_ssid=0
ssid="Default"
proto=WPA RSN
key_mgmt=NONE
pairwise=CCMP TKIP
group=CCMP TKIP WEP104 WEP40
#psk=MIA_PASS
psk=7e487a62439098f266382b89156358c339736f112bd222b0c15f8a2000e76a36
priority=10
# Plaintext connection (no WPA, no IEEE 802.1X),
# nice for hotel/airport types of WiFi network.
network={
key_mgmt=NONE
priority=10
rc.wireless.conf ( anche se a quanto pare non serve più ) :
[code]# Wireless LAN adapter configuration
# Theory of operation :
# The script attempts to match a block of settings to the specific wireless
# card inserted, the *first* block matching the card is used.
# The address format is "hwaddr", with * as a wildcard.
# 'hwaddr' is the unique MAC address identifier of the wireless card.
# The MAC address is usually printed on the card, or can be found via ifconfig.
# Some examples here use only half of the MAC address with a wildcard to
# match a whole family of cards...
# All the Wireless specific configuration is done through the Wireless
# Extensions, so we will just call 'iwconfig' with the right parameters
# defined below.
# Of course, you need to have iwconfig installled on your system.
# To download iwconfig, or for more info on Wireless Extensions :
# http://www.hpl.hp.com/personal/Jean_Tou ... Tools.html
# Note : you don't need to fill all parameters, leave them blank, in most
# cases the driver will initialise itself with sane defaults values or
# automatically figure out the value... And no drivers do support all
# possible settings...
# -- This is a modified '/etc/pcmcia/wireless.opts' script --
# -- I added sections for Prism/GT and Atheros based cards --
# -- (supported by the prism54 and madwifi drivers) --
# -- 16/sep/2004 * Eric Hameleers --
VERBOSE=1
case "$HWADDR" in
## NOTE : Comment out the following five lines to activate the samples below ...
## --------- START SECTION TO REMOVE -----------
## Pick up any Access Point, should w
