[RISOLTO] Problemi con azureus
Silentwave
Messaggioda Silentwave » sab nov 12, 2011 18:34
Ho scaricato e estratto il bz2 di vuze dal sito ufficile ma quando dò ./azureus il programma non parte e viene questo output:
root@darkstar:~/Desktop/vuze# ./azureus
Starting Azureus...
Suitable java version found [java = 1.6.0_25]
Configuring environment...
Java exec found in PATH. Verifying...
Browser check failed with: InvocationTargetException, No more handles [Unknown Mozilla path (MOZILLA_FIVE_HOME not set)]
Auto-scanning for GRE/XULRunner.  You can skip this by appending the GRE path to LD_LIBRARY_PATH and setting MOZILLA_FIVE_HOME.
  checking /usr/lib64/mozilla for GRE
        Can not use GRE from /usr/lib64/mozilla because it's missing libxpcom.so.
  checking /usr/lib64/seamonkey-2.1b3 for GRE
GRE found at /usr/lib64/seamonkey-2.1b3.
Browser check failed with: InvocationTargetException, XPCOM error -2147467261
Can't create browser.  Will try to set LD_LIBRARY_PATH and hope Vuze has better luck.
setting LD_LIBRARY_PATH to: /usr/lib64/seamonkey-2.1b3
setting MOZILLA_FIVE_HOME to: /usr/lib64/seamonkey-2.1b3
Loading Azureus:
java -Xmx128m -cp "./Azureus2.jar:./swt.jar" -Djava.library.path="/root/Desktop/vuze" -Dazureus.install.path="/root/Desktop/vuze" -Dazureus.script="./azureus" -Dazureus.script.version=2 org.gudy.azureus2.ui.swt.Main
file:/root/Desktop/vuze/Azureus2.jar ; file:/root/Desktop/vuze/swt.jar ; file:/root/Desktop/vuze/
java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
        at java.lang.reflect.Constructor.newInstance(Unknown Source)
        at org.gudy.azureus2.ui.swt.Main.<init>(Main.java:114)
        at org.gudy.azureus2.ui.swt.Main.main(Main.java:292)
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at com.aelitis.azureus.launcher.MainExecutor$1.run(MainExecutor.java:37)
        at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.UnsatisfiedLinkError: Could not load SWT library. Reasons:
        no swt-gnome-gtk-3802 in java.library.path
        no swt-gnome-gtk in java.library.path
        /root/.swt/lib/linux/x86_64/libswt-gnome-gtk-3802.so: libgnomevfs-2.so.0: impossibile aprire il file oggetto condiviso: File o directory non esistente
        Can't load library: /root/.swt/lib/linux/x86_64/libswt-gnome-gtk.so
        at org.eclipse.swt.internal.Library.loadLibrary(Library.java:285)
        at org.eclipse.swt.internal.Library.loadLibrary(Library.java:194)
        at org.eclipse.swt.internal.gnome.GNOME.<clinit>(GNOME.java:21)
        at org.eclipse.swt.program.Program.gnome_24_launch(Program.java:397)
        at org.eclipse.swt.program.Program.launch(Program.java:1086)
        at org.eclipse.swt.program.Program.launch(Program.java:1042)
        at org.gudy.azureus2.ui.swt.Utils.launch(Utils.java:955)
        at com.aelitis.azureus.ui.swt.Initializer.checkInstallID(Initializer.java:303)
        at com.aelitis.azureus.ui.swt.Initializer.runInSWTThread(Initializer.java:272)
        at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.<init>(SWTThread.java:271)
        at org.gudy.azureus2.ui.swt.mainwindow.SWTThread.createInstance(SWTThread.java:63)
        at com.aelitis.azureus.ui.swt.Initializer.<init>(Initializer.java:162)
        ... 12 more
Exit from Azureus complete
No shutdown tasks to do
Azureus TERMINATED.
Ho provato a installare dai repository tutti pacchettu gtk perchè mi è sembrato fosse lì il problema ma non ho risolto niente
Ultima modifica di Silentwave il lun nov 14, 2011 15:09, modificato 1 volta in totale.
neongen
Nome Cognome: Enrico
Slackware: 14.0_64
Kernel: 3.4.4
Desktop: KDE 4.5.5
Distribuzione: Maemo 5
Re: Problemi con azureus
Messaggioda neongen » sab nov 12, 2011 20:27
penso tu debba rimpiazzare il file swt.jar con quello a 64bit http://download.eclipse.org/eclipse/dow ... ex.php#SWT
Silentwave
Messaggioda Silentwave » sab nov 12, 2011 21:17
neongen ha scritto:penso tu debba rimpiazzare il file swt.jar con quello a 64bit http://download.eclipse.org/eclipse/dow ... ex.php#SWT
Io non ho neanche il vecchio in che directory devo metterlo questo?
neongen
Slackware: 14.0_64
Kernel: 3.4.4
Desktop: KDE 4.5.5
Messaggioda neongen » dom nov 13, 2011 11:15
nella dir di vuze. dal tuo primo post direi ~/Desktop/vuze
Silentwave
Messaggioda Silentwave » dom nov 13, 2011 11:55
neongen ha scritto:nella dir di vuze. dal tuo primo post direi ~/Desktop/vuze
niente l'errore persiste sembra che manchino due librerie:
root@SilentwavePc:~/Desktop/vuze# ./azureus
Starting Azureus...
  checking /usr/lib/seamonkey for GRE
        Can not use GRE from /usr/lib/seamonkey because it's missing libxpcom.so.
  checking /usr/lib/seamonkey-1.1.17 for GRE
        Can not use GRE from /usr/lib/seamonkey-1.1.17 because it's missing libxpcom.so.
Loading Azureus:
        no swt-gnome-gtk-3738 in java.library.path
        Can't load library: /root/.swt/lib/linux/x86_64/libswt-gnome-gtk-3738.so
        /root/.swt/lib/linux/x86_64/libswt-gnome-gtk-3738.so: libgnomevfs-2.so.0: impossibile aprire il file oggetto condiviso: File o directory non esistente
        at org.eclipse.swt.internal.Library.loadLibrary(Unknown Source)
        at org.eclipse.swt.internal.gnome.GNOME.<clinit>(Unknown Source)
        at org.eclipse.swt.program.Program.gnome_24_launch(Unknown Source)
        at org.eclipse.swt.program.Program.launch(Unknown Source)
        ... 12 more
Azureus TERMINATED.
miklos
Slackware: 14.1 64bit
Kernel: 3.16.3
Desktop: openbox 3.5.2
Messaggioda miklos » dom nov 13, 2011 12:12
ma sicuro di aver scaricato la versione a 64bit?!?!
Silentwave
Messaggioda Silentwave » dom nov 13, 2011 12:18
miklos ha scritto:ma sicuro di aver scaricato la versione a 64bit?!?!
Sicurissimo ahah ieri ho installato multilib e ora vanno programmi come skype e dropbox.. prima non andavano
Messaggioda targzeta » dom nov 13, 2011 20:34
Perché non procedi per gradi ed inizi a risolvere questi due problemi:
Il problema più grave è il secondo. Come mai non trova quel file? Dov'è?
P.S. Comunque non ti consiglio di usare l'utente root per queste cose.
Linux Registered User #454438
20/04/2013 - Io volevo Rodotà
Silentwave
Messaggioda Silentwave » lun nov 14, 2011 10:06
spina ha scritto:Perché non procedi per gradi ed inizi a risolvere questi due problemi:
La directory c'è ma manca il file e su internet non lo trovo, mi dite come fare?
hashbang
Nome Cognome: Luca De Pandis
Distribuzione: macOS
Messaggioda hashbang » lun nov 14, 2011 11:03
Hai provato ad installare questo pacchetto?
EDIT: Su AUR vengono segnalate come dipendenze: gnome-vfs (te l'ho linkato prima), libgnome e libgnomeui.
Estendo quindi la domanda che ho scritto poco più sopra anche per questi ultimi due pacchetti segnalati.
Silentwave
Messaggioda Silentwave » lun nov 14, 2011 11:27
Ho installato tutti e tre questi pacchetti e il problema persiste:
Starting Azureus...
Loading Azureus:
        /root/.swt/lib/linux/x86_64/libswt-gnome-gtk-3802.so: libgconf-2.so.4: impossibile aprire il file oggetto condiviso: File o directory non esistente
        ... 12 more
Azureus TERMINATED.
hashbang
Messaggioda hashbang » lun nov 14, 2011 14:54
Beh no. Non è lo stesso problema di prima. Ora l'errore è dato dalla mancanza di altre librerie. In particolare, richiede GConf e la sua dipendenza ORBit2
Che poi se non ricordo male dovrebbero essere dipendenze di quelle che ti ho linkato prima.
Silentwave
Messaggioda Silentwave » lun nov 14, 2011 15:08
grazie mille per l'aiuto
