[RISOLTO] k3b non trova il device
spiri
Linux 2.0
Linux 2.0
Messaggioda spiri » lun giu 04, 2012 8:35
Ciao a tutti,
ho un problema strano con k3b. non trova il mio cdrom. i permessi sono ok. sono nel gruppo cdrom. il cdrom lo uso normalmente per sentire la musia e l'ho usato da shell per masterizzare una iso con growisofs
cdrecord -scanbus da:
scsibus4:
   4,0,0   400) 'ATA     ' 'Hitachi HTS54503' 'PB3O' Disk
   4,1,0   401) *
   4,2,0   402) *
   4,3,0   403) *
   4,4,0   404) *
   4,5,0   405) *
   4,6,0   406) *
   4,7,0   407) *
scsibus5:
   5,0,0   500) 'Slimtype' 'DS8A5SH         ' 'XP91' Removable CD-ROM
   5,1,0   501) *
   5,2,0   502) *
   5,3,0   503) *
   5,4,0   504) *
   5,5,0   505) *
   5,6,0   506) *
   5,7,0   507) *
hald e' in background. non so cosa altro vedere. grazie
and
Ultima modifica di spiri il ven giu 08, 2012 15:44, modificato 2 volte in totale.
joseph
Linux 2.4
Linux 2.4
Kernel: 3.2.9
Re: k3b non trova il device
Messaggioda joseph » lun giu 04, 2012 9:48
Che messaggio ti da se lanci k3b da console? E' strano dovrebbe essere ok :)
spiri
Linux 2.0
Linux 2.0
Messaggioda spiri » lun giu 04, 2012 9:50
k3b
QDBusConnection: session D-Bus connection created before QCoreApplication. Application may misbehave.
KGlobal::locale::Warning your global KLocale is being recreated with a valid main component instead of a fake component, this usually means you tried to call i18n related functions before your main component was created. You should not do that since it most likely will not work
QGtkStyle was unable to detect the current GTK+ theme.
spiri@slackviruz:ARS$ QStringList Solid::Backends::UDisks::UDisksManager::allDevicesInternal() error: "org.freedesktop.DBus.Error.ServiceUnknown"
k3b(31034)/kdeui (kdelibs): Attempt to use QAction "view_projects" with KXMLGUIFactory!
k3b(31034)/kdeui (kdelibs): Attempt to use QAction "view_dir_tree" with KXMLGUIFactory!
k3b(31034)/kdeui (kdelibs): Attempt to use QAction "view_contents" with KXMLGUIFactory!
k3b(31034)/kdeui (kdelibs): Attempt to use QAction "location_bar" with KXMLGUIFactory!
k3b(31034) KSambaSharePrivate::testparmParamValue: We got some errors while running testparm "Load smb config files from /etc/samba/smb.conf
Error loading services.
k3b(31034) KSambaSharePrivate::findSmbConf: KSambaShare: Could not find smb.conf!
la cosa strana e' che ho dovuto installare samba per far funzionare k3b ....
RedSkull92
Linux 2.6
Linux 2.6
Slackware: 64bit -current
Kernel: 3.5.4
Desktop: FluxBox
Messaggioda RedSkull92 » lun giu 04, 2012 13:43
Anche a me dà problemi, non mi rivela il device.
Mentre da console riesco a masterizzare perfettamente.
spiri
Linux 2.0
Linux 2.0
Messaggioda spiri » lun giu 04, 2012 13:47
dimenticavo sono su current
spiri
Linux 2.0
Linux 2.0
Messaggioda spiri » lun giu 04, 2012 16:41
allora ho fatto un po' di prove. se metto un cd/dvd non audio nessun problema. funziona tutto. se metto audio niente. k3b e kaudiocreator non vedono devices. se apro xine e faccio play su cd sento la musica.
qualche consiglio su come agire??
joseph
Linux 2.4
Linux 2.4
Kernel: 3.2.9
Messaggioda joseph » lun giu 04, 2012 16:59
Hai provato a controllare i link simbolici al device?
ls -l /dev/dvd*
ls -l /dev/cdr*
Posta un pò il risultato...Magari non trova il dispositivo su un link che dice lui e si imballa :D
spiri
Linux 2.0
Linux 2.0
Messaggioda spiri » lun giu 04, 2012 17:05
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/dvd -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/dvd1 -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/dvdrw -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/dvdrw1 -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/dvdwriter -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/dvdwriter1 -> sr0
e
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/cdr -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/cdr1 -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/cdrom -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/cdrom1 -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/cdrw -> sr0
lrwxrwxrwx 1 root root 3 Jun  4 16:28 /dev/cdrw1 -> sr0
mi sembrano corretti
Ultima modifica di spiri il lun giu 04, 2012 22:57, modificato 1 volta in totale.
Messaggioda conraid » lun giu 04, 2012 18:03
spiri cerca di mettere il codice tra i tag CODE
comunque leggendo la discussione e guardando l'intervento di redskull mi vengono in mente due considerazioni
- k3b adesso non usa più hal
- tutta la discussione che facemmo con redskull perde valore, visto che per lui l'errore era in hald, ora k3b si interfaccia con udev (mi sembra con udisk, non ho ancora approfondito la cosa)
il comando
udevadm info --query=all --name=cdrom
cosa restituisce?
k3bsetup ti vede il device?
spiri
Linux 2.0
Linux 2.0
Messaggioda spiri » lun giu 04, 2012 22:57
ops scusa. lanciato il comando questo output
P: /devices/pci0000:00/0000:00:1f.2/ata4/host5/target5:0:0/5:0:0:0/block/sr0
N: sr0
S: scd0
S: disk/by-path/pci-0000:00:1f.2-scsi-0:0:0:0
S: cdrom1
S: cdrom
S: cdr1
S: cdr
S: cdwriter1
S: cdwriter
S: cdrw1
S: cdrw
S: writer
S: dvd1
S: dvd
S: dvdrw1
S: dvdrw
S: dvdwriter1
S: dvdwriter
E: UDEV_LOG=3
E: DEVPATH=/devices/pci0000:00/0000:00:1f.2/ata4/host5/target5:0:0/5:0:0:0/block/sr0
E: MAJOR=11
E: MINOR=0
E: DEVNAME=/dev/sr0
E: DEVTYPE=disk
E: SUBSYSTEM=block
E: ID_CDROM=1
E: ID_CDROM_CD_R=1
E: ID_CDROM_CD_RW=1
E: ID_CDROM_DVD=1
E: ID_CDROM_DVD_R=1
E: ID_CDROM_DVD_RAM=1
E: ID_SCSI=1
E: ID_VENDOR=Slimtype
E: ID_VENDOR_ENC=Slimtype
E: ID_MODEL=DS8A5SH
E: ID_MODEL_ENC=DS8A5SH\x20\x20\x20\x20\x20\x20\x20\x20\x20
E: ID_REVISION=XP91
E: ID_TYPE=cd
E: ID_BUS=scsi
E: ID_PATH=pci-0000:00:1f.2-scsi-0:0:0:0
E: GENERATED=1
E: DEVLINKS=/dev/scd0 /dev/disk/by-path/pci-0000:00:1f.2-scsi-0:0:0:0 /dev/cdrom1 /dev/cdrom /dev/cdr1 /dev/cdr /dev/cdwriter1 /dev/cdwriter /dev/cdrw1 /dev/cdrw /dev/writer /dev/dvd1 /dev/dvd /dev/dvdrw1 /dev/dvdrw /dev/dvdwriter1 /dev/dvdwriter
E: TAGS=:udev-acl:
k3bsetup mi dice che nn trova nessun device. ho provato a cambiare i permessi ma non trova proprio il dev. anche kaudiocreator non trova il device.
ripeto questo e' un problema con i cd audio.
Messaggioda conraid » mar giu 05, 2012 8:56
aspetta non ho capito, k3b ti vede il device se c'è un cd vuoto o dati, e non se c'è un cd audio?
spiri
Linux 2.0
Linux 2.0
Messaggioda spiri » mar giu 05, 2012 9:29
praticamente se metto un cd audio e voglio per esempio trasformare le tracce in mp3 non mi vede il device. lo stesso se uso kaudiocreator. pero' se uso qualsiasi programma per sentire il cd audio lo sento.
il cd dati lo monta senza problemi. non ho provato a vedere se metto un cd vuoto come si comporta k3b
Messaggioda conraid » mar giu 05, 2012 9:38
Ho provato adesso, a me compare la finestra di KDE che mi chiede cosa fare e dico "estrai tracce con k3b" e parte k3b.
Non è che appena lo inserisci parte qualche programma in automatico che prende "possesso" del lettore?
Guarda se nel centro di controllo, in Hardware->Dispositivi rimovibili hai "Abilita montaggio automatico dei supporti removibili". Se sì toglilo e riprova.
E' solo una prova, non so se è quello il problema, ma a questo punto sembra un problema di configurazione di kde, anche se nel profilo leggo che usi xfce, ma leggo anche che usi una 13.37 mentre stai parlando di una -current :-)
Se usi xfce non saprei, non lo conosco, però tieni conto che k3b usa le impostazioni di KDE per alcune operazioni
spiri
Linux 2.0
Linux 2.0
Messaggioda spiri » mar giu 05, 2012 10:21
ok. si scusa devo aggiornare il mio profilo. parto in init 3 ed uso 99% delle volte xfce ed a volte kde per fare vedere quanto e' bello linux ....
comunque provero' a fare lo stesso con kde. vediamo
inoltre poi sono sulla current indi puo' essere un bug
grazie del tuo aiuto
and
spiri
Linux 2.0
Linux 2.0
Re: [RISOLTO] k3b non trova il device
Messaggioda spiri » ven giu 08, 2012 15:46
niente neanche da KDE funziona. quindi alla fine ho risolto grazie al buon Alien:
http://alien.slackbook.org/blog/kde-4-6-first-release-candidate/
SOLID_HAL_LEGACY=1 k3b
did it the trick!!!! \:D/ \:D/
maggiori info:
http://websvn.kde.org/?view=revision&revision=1206281
