[RISOLTO] connessione ad hoc da chiavetta
pegaso
Messaggioda pegaso » ven nov 16, 2012 19:33
Sapreste indicarmi come creare una connessione ad hoc sfruttando la chiavetta della 3?
Vi do alcune informazioni che potrebbero essere utili:
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 12d1:1506 Huawei Technologies Co., Ltd. E398 LTE/UMTS/GSM Modem/Networkcard
ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 00:16:d4:01:1d:12  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 16436
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 0  (Local Loopback)
        RX packets 8  bytes 480 (480.0 B)
        TX packets 8  bytes 480 (480.0 B)
ppp0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST>  mtu 1440
        inet 10.81.71.72  netmask 255.255.255.255  destination 10.64.64.64
        ppp  txqueuelen 3  (Point-to-Point Protocol)
        RX packets 47332  bytes 54715164 (52.1 MiB)
        TX packets 33743  bytes 5745579 (5.4 MiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet6 fe80::213:2ff:fe32:43b0  prefixlen 64  scopeid 0x20<link>
        ether 00:13:02:32:43:b0  txqueuelen 1000  (Ethernet)
        RX packets 21  bytes 1337 (1.3 KiB)
        TX packets 6  bytes 588 (588.0 B)
Vorrei precisare che i pc che devono connettersi a questa rete hanno windows come sistema operativo. Grazie.
Ultima modifica di pegaso il lun nov 19, 2012 13:10, modificato 1 volta in totale.
pegaso
Re: connessione ad hoc da chiavetta
Messaggioda pegaso » dom nov 18, 2012 12:23
up!
Messaggioda ZeroUno » dom nov 18, 2012 12:55
mi sa che non ti sei spiegato bene.
Vediamo se è così:
tu vuoi connettere la chiavetta 3 al tuo pc linux e con windows vuoi andare su internet tramite linux. Corretto?
ifconfig wlan0 down
iwconfig wlan0 mode ad-hoc essid AXYZ key 12345678901234567890123456 open rate 54M
ifconfig wlan0 30.0.0.1 netmask 255.255.255.0 broadcast 30.0.0.255 up
echo 1 > /proc/sys/net/ipv4/ip_forward
iptables -t nat -F
iptables -t nat -A POSTROUTING -s 30.0.0.0/24 -j MASQUERADE
Sul pc windows imposti la scheda di rete wifi con ip statico 30.0.0.2 netmask 255.255.255.0 gateway 30.0.0.1 dns 8.8.8.8
Poi fai ricerca nuove wifi, connettiti alla wifi chiamata AXYZ e come password metti 12345678901234567890123456
Ti puoi connettere con un solo pc (la connessione adhoc supporta una sola connessione)
pegaso
Messaggioda pegaso » lun nov 19, 2012 13:09
Una sola parola: Perfetto!! :D
Grazie mille per la precisione ;)
EDIT:
Se permettete un piccolo OT come faccio a far avviare i programmi che richiedono X all'avvio? In particolare vorrei far avviare keepassx all'avvio del sistema ma se lo inserisco in rc.local dice che il sistema X non è ancora stato avviato!
Re: [RISOLTO] connessione ad hoc da chiavetta
Messaggioda ZeroUno » lun nov 19, 2012 14:50
mettili in .kde/Autostart
