Problema con slackware64-14.1 e driver Nvidia
varjag
Messaggioda varjag » mar nov 12, 2013 0:25
Installato slackware64-14.1
installato multilib seguendo la guida di Alien Bob
kernel-generic-3.10.17
Compilato e installato slackbuilds di SBo per nvidia-driver-331.20 , modificato compat32=yes
Certamente installato anche nvidia-kernel e libvdpau
Modificato slackbuilds solo di libvdpau per lincare lib64
  SLKCFLAGS="-O2 -fPIC"
  SLKLDFLAGS="-L/usr/lib64"
  LIBDIRSUFFIX="64"
else
  SLKCFLAGS="-O2"
  LIBDIRSUFFIX=""
fi
LDFLAGS="$SLKLDFLAGS" \
CFLAGS="$SLKCFLAGS" \
CXXFLAGS="$SLKCFLAGS" \
./configure \
Blacklistato nouveau
A riavvio non si carica il modulo GLX e temperatura di GPU elevata.
Ho googlato ma non ho trovato la soluzione.
Xorg.O.log
[    52.437]
X.Org X Server 1.14.3
Release Date: 2013-09-12
[    52.438] X Protocol Version 11, Revision 0
[    52.438] Build Operating System: Slackware 14.1 Slackware Linux Project
[    52.439] Current Operating System: Linux darkstar 3.10.17 #2 SMP Wed Oct 23 16:34:38 CDT 2013 x86_64
[    52.439] Kernel command line: BOOT_IMAGE=/boot/vmlinuz root=/dev/sda7
[    52.439] Build Date: 09 October 2013  08:27:11PM
[    52.439]
[    52.440] Current version of pixman: 0.30.2
[    52.440]    Before reporting problems, check http://wiki.x.org
[    52.440] Markers: (--) probed, (**) from config file, (==) default setting,
[    52.442] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Nov 11 20:07:48 2013
[    52.484] (==) Using config file: "/etc/X11/xorg.conf"
[    52.484] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    52.503] (==) ServerLayout "Layout0"
[    52.503] (**) |-->Screen "Screen0" (0)
[    52.503] (**) |   |-->Monitor "Monitor0"
[    52.503] (**) |   |-->Device "Device0"
[    52.503] (**) |-->Input Device "Keyboard0"
[    52.503] (**) |-->Input Device "Mouse0"
[    52.504] (==) Automatically adding devices
[    52.504] (==) Automatically enabling devices
[    52.504] (==) Automatically adding GPU devices
[    52.573] (WW) The directory "/usr/share/fonts/local" does not exist.
[    52.573]    Entry deleted from font path.
[    52.573] (WW) The directory "/usr/share/fonts/CID" does not exist.
[    52.573] (**) FontPath set to:
   /usr/lib64/X11/fonts/misc/:unscaled,
   /usr/lib64/X11/fonts/100dpi/:unscaled,
   /usr/lib64/X11/fonts/75dpi/:unscaled,
   /usr/lib64/X11/fonts/misc/,
   /usr/lib64/X11/fonts/Type1/,
   /usr/lib64/X11/fonts/Speedo/,
   /usr/lib64/X11/fonts/100dpi/,
   /usr/lib64/X11/fonts/75dpi/,
   /usr/lib64/X11/fonts/cyrillic/,
   /usr/lib64/X11/fonts/TTF/,
   /usr/share/fonts/TTF,
   /usr/share/fonts/OTF,
   /usr/share/fonts/Type1,
   /usr/share/fonts/misc,
   /usr/share/fonts/75dpi,
   /usr/share/fonts/100dpi,
   /usr/share/fonts/cyrillic
[    52.573] (==) ModulePath set to "/usr/lib64/xorg/modules"
[    52.573] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    52.573] (WW) Disabling Keyboard0
[    52.573] (WW) Disabling Mouse0
[    52.573] (II) Loader magic: 0x7f6d20
[    52.573] (II) Module ABI versions:
[    52.573]    X.Org ANSI C Emulation: 0.4
[    52.573]    X.Org Video Driver: 14.1
[    52.573]    X.Org XInput driver : 19.1
[    52.573]    X.Org Server Extension : 7.0
[    52.574] (II) xfree86: Adding drm device (/dev/dri/card0)
[    52.577] (--) PCI:*(0:1:0:0) 10de:124d:1028:0570 rev 161, Mem @ 0xd4000000/33554432, 0xc0000000/268435456, 0xd0000000/67108864, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[    52.577] (II) Open ACPI successful (/var/run/acpid.socket)
[    52.578] Initializing built-in extension Generic Event Extension
[    52.578] Initializing built-in extension SHAPE
[    52.578] Initializing built-in extension MIT-SHM
[    52.578] Initializing built-in extension XInputExtension
[    52.579] Initializing built-in extension XTEST
[    52.579] Initializing built-in extension BIG-REQUESTS
[    52.579] Initializing built-in extension SYNC
[    52.579] Initializing built-in extension XKEYBOARD
[    52.580] Initializing built-in extension XC-MISC
[    52.581] Initializing built-in extension XINERAMA
[    52.581] Initializing built-in extension XFIXES
[    52.582] Initializing built-in extension RENDER
[    52.582] Initializing built-in extension RANDR
[    52.582] Initializing built-in extension COMPOSITE
[    52.582] Initializing built-in extension DAMAGE
[    52.583] Initializing built-in extension MIT-SCREEN-SAVER
[    52.583] Initializing built-in extension DOUBLE-BUFFER
[    52.583] Initializing built-in extension RECORD
[    52.583] Initializing built-in extension DPMS
[    52.583] Initializing built-in extension X-Resource
[    52.584] Initializing built-in extension XVideo
[    52.584] Initializing built-in extension XVideo-MotionCompensation
[    52.584] Initializing built-in extension XFree86-VidModeExtension
[    52.584] Initializing built-in extension XFree86-DGA
[    52.585] Initializing built-in extension XFree86-DRI
[    52.585] Initializing built-in extension DRI2
[    52.585] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[    52.585] (II) LoadModule: "glx"
[    52.588] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[    52.604] (II) Module glx: vendor="X.Org Foundation"
[    52.604]    compiled for 1.14.3, module version = 1.0.0
[    52.604]    ABI class: X.Org Server Extension, version 7.0
[    52.604] (==) AIGLX enabled
[    52.605] Loading extension GLX
[    52.605] (II) LoadModule: "dbe"
[    52.605] (II) Module "dbe" already built-in
[    52.605] (II) LoadModule: "extmod"
[    52.605] (II) Module "extmod" already built-in
[    52.605] (II) LoadModule: "record"
[    52.605] (II) Module "record" already built-in
[    52.605] (II) LoadModule: "dri2"
[    52.605] (II) Module "dri2" already built-in
[    52.605] (II) LoadModule: "nvidia"
[    52.606] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[    52.687] (II) Module nvidia: vendor="NVIDIA Corporation"
[    52.687]    compiled for 4.0.2, module version = 1.0.0
[    52.687]    Module class: X.Org Video Driver
[    52.693] (II) NVIDIA dlloader X Driver  331.20  Wed Oct 30 17:16:53 PDT 2013
[    52.693] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    52.694] (--) using VT number 7
[    52.699] (II) Loading sub module "fb"
[    52.700] (II) LoadModule: "fb"
[    52.700] (II) Loading /usr/lib64/xorg/modules/libfb.so
[    52.707] (II) Module fb: vendor="X.Org Foundation"
[    52.707]    compiled for 1.14.3, module version = 1.0.0
[    52.707]    ABI class: X.Org ANSI C Emulation, version 0.4
[    52.707] (WW) Unresolved symbol: fbGetGCPrivateKey
[    52.707] (II) Loading sub module "wfb"
[    52.707] (II) LoadModule: "wfb"
[    52.707] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[    52.709] (II) Module wfb: vendor="X.Org Foundation"
[    52.709]    compiled for 1.14.3, module version = 1.0.0
[    52.709]    ABI class: X.Org ANSI C Emulation, version 0.4
[    52.709] (II) Loading sub module "ramdac"
[    52.709] (II) LoadModule: "ramdac"
[    52.709] (II) Module "ramdac" already built-in
[    52.723] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[    52.723] (==) NVIDIA(0): RGB weight 888
[    52.723] (==) NVIDIA(0): Default visual is TrueColor
[    52.723] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    52.726] (**) NVIDIA(0): Enabling 2D acceleration
[    52.726] (EE) NVIDIA(0): Failed to initialize the GLX module; please check in your X
[    52.726] (EE) NVIDIA(0):     log file that the GLX module has been loaded in your X
[    52.726] (EE) NVIDIA(0):     server, and that the module is the NVIDIA GLX module.  If
[    52.726] (EE) NVIDIA(0):     you continue to encounter problems, Please try
[    52.726] (EE) NVIDIA(0):     reinstalling the NVIDIA driver.
[    53.316] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[    53.317] (II) NVIDIA(0): NVIDIA GPU GeForce GT 555M (GF116) at PCI:1:0:0 (GPU-0)
[    53.317] (--) NVIDIA(0): Memory: 3145728 kBytes
[    53.317] (--) NVIDIA(0): VideoBIOS: 70.26.40.00.05
[    53.317] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    53.536] (--) NVIDIA(0): Valid display device(s) on GeForce GT 555M at PCI:1:0:0
[    53.536] (--) NVIDIA(0):     DFP-0
[    53.536] (--) NVIDIA(0):     DFP-1
[    53.536] (--) NVIDIA(0):     LGD (DFP-2) (boot, connected)
[    53.536] (--) NVIDIA(0):     DFP-3
[    53.536] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[    53.536] (--) NVIDIA(0): DFP-0: 165.0 MHz maximum pixel clock
[    53.536] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[    53.536] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[    53.536] (--) NVIDIA(0): LGD (DFP-2): Internal DisplayPort
[    53.536] (--) NVIDIA(0): LGD (DFP-2): 480.0 MHz maximum pixel clock
[    53.536] (--) NVIDIA(0): DFP-3: Internal DisplayPort
[    53.536] (--) NVIDIA(0): DFP-3: 480.0 MHz maximum pixel clock
[    53.536] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    53.536] (**) NVIDIA(0):     device LGD (DFP-2) (Using EDID frequencies has been
[    53.536] (**) NVIDIA(0):     enabled on all display devices.)
[    53.547] (==) NVIDIA(0):
[    53.547] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    53.547] (==) NVIDIA(0):     will be used as the requested mode.
[    53.547] (II) NVIDIA(0): Validated MetaModes:
[    53.547] (II) NVIDIA(0):     "DFP-2:nvidia-auto-select"
[    53.547] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[    53.561] (--) NVIDIA(0): DPI set to (128, 130); computed from "UseEdidDpi" X config
[    53.561] (--) NVIDIA(0):     option
[    53.561] (--) Depth 24 pixmap format is 32 bpp
[    53.561] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[    53.561] (II) NVIDIA:     access.
[    53.681] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select"
[    53.793] Loading extension NV-GLX
[    53.862] (==) NVIDIA(0): Disabling shared memory pixmaps
[    53.862] (==) NVIDIA(0): Backing store disabled
[    53.862] (==) NVIDIA(0): Silken mouse enabled
[    53.870] (**) NVIDIA(0): DPMS enabled
[    53.870] Loading extension NV-CONTROL
[    53.870] Loading extension XINERAMA
[    53.870] (II) Loading sub module "dri2"
[    53.870] (II) LoadModule: "dri2"
[    53.870] (II) Module "dri2" already built-in
[    53.870] (II) NVIDIA(0): [DRI2] Setup complete
[    53.870] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    53.870] (--) RandR disabled
[    53.876] (II) AIGLX: Screen 0 is not DRI2 capable
[    53.876] (II) AIGLX: Screen 0 is not DRI capable
[    53.972] (II) AIGLX: Loaded and initialized swrast
[    53.972] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[    54.373] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[    54.373] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    54.374] (**) Power Button: Applying InputClass "keyboard-all"
[    54.374] (II) LoadModule: "evdev"
[    54.386] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[    54.402] (II) Module evdev: vendor="X.Org Foundation"
[    54.402]    compiled for 1.14.3, module version = 2.8.2
[    54.402]    Module class: X.Org XInput Driver
[    54.402]    ABI class: X.Org XInput driver, version 19.1
[    54.402] (II) Using input driver 'evdev' for 'Power Button'
[    54.402] (**) Power Button: always reports core events
[    54.402] (**) evdev: Power Button: Device: "/dev/input/event5"
[    54.402] (--) evdev: Power Button: Vendor 0 Product 0x1
[    54.402] (--) evdev: Power Button: Found keys
[    54.402] (II) evdev: Power Button: Configuring as keyboard
[    54.402] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input5/event5"
[    54.402] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    54.402] (**) Option "xkb_rules" "evdev"
[    54.402] (**) Option "xkb_model" "pc104"
[    54.402] (**) Option "xkb_layout" "us"
[    54.402] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    54.426] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[    54.426] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    54.426] (**) Video Bus: Applying InputClass "keyboard-all"
[    54.426] (II) Using input driver 'evdev' for 'Video Bus'
[    54.426] (**) Video Bus: always reports core events
[    54.426] (**) evdev: Video Bus: Device: "/dev/input/event7"
[    54.426] (--) evdev: Video Bus: Vendor 0 Product 0x6
[    54.426] (--) evdev: Video Bus: Found keys
[    54.426] (II) evdev: Video Bus: Configuring as keyboard
[    54.426] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/device:2c/LNXVIDEO:00/input/input7/event7"
[    54.426] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    54.426] (**) Option "xkb_rules" "evdev"
[    54.426] (**) Option "xkb_model" "pc104"
[    54.426] (**) Option "xkb_layout" "us"
[    54.426] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    54.426] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    54.426] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    54.426] (**) Power Button: Applying InputClass "keyboard-all"
[    54.426] (II) Using input driver 'evdev' for 'Power Button'
[    54.426] (**) Power Button: always reports core events
[    54.426] (**) evdev: Power Button: Device: "/dev/input/event2"
[    54.426] (--) evdev: Power Button: Vendor 0 Product 0x1
[    54.426] (--) evdev: Power Button: Found keys
[    54.426] (II) evdev: Power Button: Configuring as keyboard
[    54.426] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input2/event2"
[    54.426] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    54.427] (II) config/udev: Adding input device Lid Switch (/dev/input/event4)
[    54.427] (II) No input driver specified, ignoring this device.
[    54.427] (II) This device may have been added with another device file.
[    54.427] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
[    54.427] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    54.427] (**) Sleep Button: Applying InputClass "keyboard-all"
[    54.427] (II) Using input driver 'evdev' for 'Sleep Button'
[    54.427] (**) Sleep Button: always reports core events
[    54.427] (**) evdev: Sleep Button: Device: "/dev/input/event3"
[    54.427] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[    54.427] (--) evdev: Sleep Button: Found keys
[    54.427] (II) evdev: Sleep Button: Configuring as keyboard
[    54.427] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input3/event3"
[    54.427] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[    54.427] (**) Option "xkb_rules" "evdev"
[    54.427] (**) Option "xkb_model" "pc104"
[    54.427] (**) Option "xkb_layout" "us"
[    54.427] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    54.428] (II) config/udev: Adding drm device (/dev/dri/card0)
[    54.428] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[    54.428] (II) No input driver specified, ignoring this device.
[    54.428] (II) This device may have been added with another device file.
[    54.428] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event13)
[    54.428] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[    54.429] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event15)
[    54.429] (II) No input driver specified, ignoring this device.
[    54.429] (II) This device may have been added with another device file.
[    54.429] (II) config/udev: Adding input device Laptop_Integrated_Webcam_2HDM (/dev/input/event17)
[    54.429] (**) Laptop_Integrated_Webcam_2HDM: Applying InputClass "evdev keyboard catchall"
[    54.429] (**) Laptop_Integrated_Webcam_2HDM: Applying InputClass "keyboard-all"
[    54.429] (II) Using input driver 'evdev' for 'Laptop_Integrated_Webcam_2HDM'
[    54.429] (**) Laptop_Integrated_Webcam_2HDM: always reports core events
[    54.429] (**) evdev: Laptop_Integrated_Webcam_2HDM: Device: "/dev/input/event17"
[    54.429] (--) evdev: Laptop_Integrated_Webcam_2HDM: Vendor 0x408 Product 0x2fb1
[    54.429] (--) evdev: Laptop_Integrated_Webcam_2HDM: Found keys
[    54.429] (II) evdev: Laptop_Integrated_Webcam_2HDM: Configuring as keyboard
[    54.429] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input17/event17"
[    54.429] (II) XINPUT: Adding extended input device "Laptop_Integrated_Webcam_2HDM" (type: KEYBOARD, id 10)
[    54.429] (**) Option "xkb_rules" "evdev"
[    54.429] (**) Option "xkb_model" "pc104"
[    54.429] (**) Option "xkb_layout" "us"
[    54.429] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    54.430] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event10)
[    54.430] (II) No input driver specified, ignoring this device.
[    54.430] (II) This device may have been added with another device file.
[    54.430] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event8)
[    54.430] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event9)
[    54.430] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event16)
[    54.430] (**) Logitech USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[    54.430] (II) Using input driver 'evdev' for 'Logitech USB Optical Mouse'
[    54.430] (**) Logitech USB Optical Mouse: always reports core events
[    54.430] (**) evdev: Logitech USB Optical Mouse: Device: "/dev/input/event16"
[    54.430] (--) evdev: Logitech USB Optical Mouse: Vendor 0x46d Product 0xc06c
[    54.431] (--) evdev: Logitech USB Optical Mouse: Found 3 mouse buttons
[    54.431] (--) evdev: Logitech USB Optical Mouse: Found scroll wheel(s)
[    54.431] (--) evdev: Logitech USB Optical Mouse: Found relative axes
[    54.431] (--) evdev: Logitech USB Optical Mouse: Found x and y relative axes
[    54.431] (II) evdev: Logitech USB Optical Mouse: Configuring as mouse
[    54.431] (II) evdev: Logitech USB Optical Mouse: Adding scrollwheel support
[    54.431] (**) evdev: Logitech USB Optical Mouse: YAxisMapping: buttons 4 and 5
[    54.431] (**) evdev: Logitech USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    54.431] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input/input16/event16"
[    54.431] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 11)
[    54.431] (II) evdev: Logitech USB Optical Mouse: initialized for relative axes.
[    54.431] (**) Logitech USB Optical Mouse: (accel) keeping acceleration scheme 1
[    54.431] (**) Logitech USB Optical Mouse: (accel) acceleration profile 0
[    54.431] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[    54.431] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[    54.431] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse1)
[    54.431] (II) No input driver specified, ignoring this device.
[    54.431] (II) This device may have been added with another device file.
[    54.432] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event1)
[    54.432] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    54.432] (**) AT Translated Set 2 keyboard: Applying InputClass "keyboard-all"
[    54.432] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    54.432] (**) AT Translated Set 2 keyboard: always reports core events
[    54.432] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event1"
[    54.432] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[    54.432] (--) evdev: AT Translated Set 2 keyboard: Found keys
[    54.432] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[    54.432] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input1/event1"
[    54.432] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[    54.432] (**) Option "xkb_rules" "evdev"
[    54.432] (**) Option "xkb_model" "pc104"
[    54.432] (**) Option "xkb_layout" "us"
[    54.432] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    54.432] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event11)
[    54.432] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    54.432] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[    54.432] (II) LoadModule: "synaptics"
[    54.433] (II) Loading /usr/lib64/xorg/modules/input/synaptics_drv.so
[    54.438] (II) Module synaptics: vendor="X.Org Foundation"
[    54.438]    compiled for 1.14.2, module version = 1.7.1
[    54.438]    Module class: X.Org XInput Driver
[    54.438]    ABI class: X.Org XInput driver, version 19.1
[    54.438] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[    54.438] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    54.438] (**) Option "Device" "/dev/input/event11"
[    54.459] (II) synaptics: SynPS/2 Synaptics TouchPad: ignoring touch events for semi-multitouch device
[    54.459] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5398 (res 42)
[    54.459] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4728 (res 70)
[    54.459] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[    54.459] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[    54.459] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[    54.459] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[    54.459] (**) Option "TapButton1" "1"
[    54.459] (**) Option "TapButton2" "2"
[    54.459] (**) Option "TapButton3" "3"
[    54.459] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    54.459] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    54.469] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input11/event11"
[    54.469] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 13)
[    54.469] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[    54.469] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 1.75
[    54.469] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.039
[    54.469] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[    54.469] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[    54.469] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    54.469] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    54.469] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    54.470] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[    54.470] (II) No input driver specified, ignoring this device.
[    54.470] (II) This device may have been added with another device file.
[    54.471] (II) config/udev: Adding input device Speakup (/dev/input/event0)
[    54.471] (**) Speakup: Applying InputClass "evdev keyboard catchall"
[    54.471] (**) Speakup: Applying InputClass "keyboard-all"
[    54.471] (II) Using input driver 'evdev' for 'Speakup'
[    54.471] (**) Speakup: always reports core events
[    54.471] (**) evdev: Speakup: Device: "/dev/input/event0"
[    54.471] (--) evdev: Speakup: Vendor 0 Product 0
[    54.471] (--) evdev: Speakup: Found keys
[    54.471] (II) evdev: Speakup: Configuring as keyboard
[    54.471] (**) Option "config_info" "udev:/sys/devices/virtual/input/input0/event0"
[    54.471] (II) XINPUT: Adding extended input device "Speakup" (type: KEYBOARD, id 14)
[    54.471] (**) Option "xkb_rules" "evdev"
[    54.471] (**) Option "xkb_model" "pc104"
[    54.471] (**) Option "xkb_layout" "us"
[    54.471] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    54.472] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event6)
[    54.472] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    54.472] (**) Dell WMI hotkeys: Applying InputClass "keyboard-all"
[    54.472] (II) Using input driver 'evdev' for 'Dell WMI hotkeys'
[    54.472] (**) Dell WMI hotkeys: always reports core events
[    54.472] (**) evdev: Dell WMI hotkeys: Device: "/dev/input/event6"
[    54.472] (--) evdev: Dell WMI hotkeys: Vendor 0 Product 0
[    54.472] (--) evdev: Dell WMI hotkeys: Found keys
[    54.472] (II) evdev: Dell WMI hotkeys: Configuring as keyboard
[    54.472] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/event6"
[    54.472] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 15)
[    54.472] (**) Option "xkb_rules" "evdev"
[    54.472] (**) Option "xkb_model" "pc104"
[    54.472] (**) Option "xkb_layout" "us"
[    54.472] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
xorg.conf
    # nvidia-xconfig: X configuration file generated by nvidia-xconfig
    # nvidia-xconfig:  version 331.20  (root@darkstar)  Mon Nov 11 19:30:32 CET 2013
    Section "ServerLayout"
        Identifier     "Layout0"
        Screen      0  "Screen0"
        InputDevice    "Keyboard0" "CoreKeyboard"
        InputDevice    "Mouse0" "CorePointer"
    EndSection
    Section "Files"
        FontPath        "/usr/lib64/X11/fonts/misc/:unscaled"
        FontPath        "/usr/lib64/X11/fonts/100dpi/:unscaled"
        FontPath        "/usr/lib64/X11/fonts/75dpi/:unscaled"
        FontPath        "/usr/lib64/X11/fonts/misc/"
        FontPath        "/usr/lib64/X11/fonts/Type1/"
        FontPath        "/usr/lib64/X11/fonts/Speedo/"
        FontPath        "/usr/lib64/X11/fonts/100dpi/"
        FontPath        "/usr/lib64/X11/fonts/75dpi/"
        FontPath        "/usr/lib64/X11/fonts/cyrillic/"
        FontPath        "/usr/lib64/X11/fonts/TTF/"
    EndSection
    Section "Module"
        Load           "glx"
        Load           "dbe"
        Load           "extmod"
        Load           "record"
        Load           "dri2"
    EndSection
    Section "InputDevice"
        # generated from default
        Identifier     "Mouse0"
        Driver         "mouse"
        Option         "Protocol" "auto"
        Option         "Device" "/dev/psaux"
        Option         "Emulate3Buttons" "no"
        Option         "ZAxisMapping" "4 5"
    EndSection
        Identifier     "Keyboard0"
        Driver         "kbd"
    EndSection
    Section "Monitor"
        Identifier     "Monitor0"
        VendorName     "Unknown"
        ModelName      "Unknown"
        HorizSync       28.0 - 33.0
        VertRefresh     43.0 - 72.0
        Option         "DPMS"
    EndSection
    Section "Device"
        Identifier     "Device0"
        Driver         "nvidia"
        VendorName     "NVIDIA Corporation"
    EndSection
    Section "Screen"
        Identifier     "Screen0"
        Device         "Device0"
        Monitor        "Monitor0"
        DefaultDepth    24
        SubSection     "Display"
            Depth       24
        EndSubSection
    EndSection
Dove cercare il problema
grazie in anticipo
Kernel: 4.14.x
Re: Problema con slackware64-14.1 e driver Nvidia
Messaggioda aschenaz » mar nov 12, 2013 7:50
Per quella versione dei driver non so che dirti.
Io, fin dal primo passaggio al kernel 3.10.x, ho sempre installato i 325.15 presi direttamente dal sito Nvidia. Mai alcun problema.
lablinux
Desktop: Gnome
Distribuzione: Debian testing
Messaggioda lablinux » mar nov 12, 2013 15:03
Idem com aschenaz. Scarico e installo il binario direttamente dal sito di Nvidia.
brg
Kernel: 4.4.38
Desktop: KDE4
Messaggioda brg » mar nov 12, 2013 15:56
C'è un errore di installazione, ti carica il modulo glx distribuito da X.org invece che quello di Nvidia.
Il file in questione è /usr/lib64/xorg/modules/extensions/libglx.so , guarda se è un collegamento e a che cosa è collegato e se ce ne sono altre versioni nella directory /usr/lib64/xorg/modules/extensions/.
Probabilmente non ti ha sostituito i driver di X.org per l'OpenGL:
/usr/lib[64]/libGL.so.1.2
/usr/lib[64]/xorg/modules/extensions/{libglx.so libglx.la}
varjag
Messaggioda varjag » mar nov 12, 2013 16:08
Si, pensavo che e un problema con glx di xorg pero non saprei cosa fare.
 locate libglx
/usr/lib64/xorg/modules/extensions/libglx.so.325.15-nvidia
/usr/lib64/xorg/modules/extensions/libglx.la
bash-4.2# locate libGL
/usr/lib/libGLEW.so
/usr/lib/libGL.so
/usr/lib/libGLU.so
/usr/lib/libGLU.so.1
/usr/lib/libGLEW.a
/usr/lib/libGLU.la
/usr/lib/libGLEW.so.1.9
/usr/lib/libGL.so.325.15-nvidia
/usr/lib/libGL.so.1
/usr/lib/libGL.la
/usr/lib/libGLU.so.1.3.1
/usr/lib/libGLEW.so.1.9.0
/usr/lib/libGL.so.1.2.0
/usr/lib64/libGLEW.so
/usr/lib64/libGL.so
/usr/lib64/libGLU.so
/usr/lib64/libGLU.so.1
/usr/lib64/libGLEW.a
/usr/lib64/libGLU.la
/usr/lib64/libGLEW.so.1.9
/usr/lib64/libGL.so.325.15-nvidia
/usr/lib64/libGL.so.1
/usr/lib64/libGL.la
/usr/lib64/libGLU.so.1.3.1
che devo fare?
ancora non sono molto pratico con slackware. Sto imparando.
brg
Kernel: 4.4.38
Desktop: KDE4
Messaggioda brg » mar nov 12, 2013 16:24
Io farei così:
# apri un terminale come root in /usr/lib64/xorg/modules/extensions/
# rinomina libglx.so in libglx.bak
mv libglx.so libglx.bak
# crea un collegamento a libglx.so.325.15-nvidia chiamato libglx.so
ln -sn libglx.so.325.15-nvidia libglx.so
# vai in /usr/lib64/xorg/modules/ e fai lo stesso per libGL.so
mv libGL.so libGL.bak
ln -sn libGL.so.325.15-nvidia libGL.so
varjag
Messaggioda varjag » mar nov 12, 2013 16:32
mille grazie per aiuto
non ho libGL.so
bash-4.2# cd /usr/lib64/xorg/modules/
bash-4.2# ls
dri         libfb.la       libnvidia-wfb.so.325.15-nvidia  libvbe.so    v10002d.uc
drivers     libfb.so       libshadow.la                    libvgahw.la  v20002d.uc
extensions  libfbdevhw.la  libshadow.so                    libvgahw.so
input       libfbdevhw.so  libshadowfb.la                  libwfb.la
libexa.la   libint10.la    libshadowfb.so                  libwfb.so
libexa.so   libint10.so    libvbe.la                       multimedia
bash-4.2#
ce qui
/usr/lib64/libGL.so
/usr/lib/libGL.so
brg
Kernel: 4.4.38
Desktop: KDE4
Messaggioda brg » mar nov 12, 2013 16:41
Errore mio, sì è /usr/lib64/libGL.so e non /usr/lib64/xorg/modules/libGL.so
varjag
Messaggioda varjag » mar nov 12, 2013 16:45
solo per /usr/lib64/libGL.so ?
e per /usr/lib/libGL.so non fare niente?
e una multilib
brg
Kernel: 4.4.38
Desktop: KDE4
Messaggioda brg » mar nov 12, 2013 16:51
Se vuoi eseguire applicazioni a 32bit con accelerazione grafica devi fare lo stesso procedimento anche per /usr/lib/libGL.so
Ma per avviare Xorg non è necessario.
varjag
Messaggioda varjag » mar nov 12, 2013 17:21
Grazie per aiuto
sei gentilissimo
finalmente ho capito quello che scritto su SBo riguarda nvidia-driver
glx abilitato
glxinfo
name of display: :0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:.....
bash-4.2$
Xorg.0.log
[    62.035]
[    62.036] X Protocol Version 11, Revision 0
[    62.036] Build Operating System: Slackware 14.1 Slackware Linux Project
[    62.037] Current Operating System: Linux darkstar 3.10.17 #2 SMP Wed Oct 23 16:34:38 CDT 2013 x86_64
[    62.037] Kernel command line: BOOT_IMAGE=/boot/vmlinuz root=/dev/sda7
[    62.037] Build Date: 09 October 2013  08:27:11PM
[    62.037]
[    62.038] Current version of pixman: 0.30.2
[    62.038]    Before reporting problems, check http://wiki.x.org
[    62.038] Markers: (--) probed, (**) from config file, (==) default setting,
[    62.040] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov 12 17:00:31 2013
[    62.078] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    62.122] (==) No Layout section.  Using the first Screen section.
[    62.122] (==) No screen section available. Using defaults.
[    62.122] (**) |-->Screen "Default Screen Section" (0)
[    62.122] (**) |   |-->Monitor "<default monitor>"
[    62.122] (==) No device specified for screen "Default Screen Section".
   Using the first device section listed.
[    62.122] (**) |   |-->Device "Device0"
[    62.122] (==) No monitor specified for screen "Default Screen Section".
   Using a default monitor configuration.
[    62.122] (==) Automatically adding devices
[    62.122] (==) Automatically enabling devices
[    62.122] (==) Automatically adding GPU devices
[    62.135] (WW) The directory "/usr/share/fonts/local" does not exist.
[    62.135]    Entry deleted from font path.
[    62.135] (WW) The directory "/usr/share/fonts/CID" does not exist.
[    62.211] (==) FontPath set to:
[    62.211] (==) ModulePath set to "/usr/lib64/xorg/modules"
[    62.211] (II) The server relies on udev to provide the list of input devices.
   If no devices become available, reconfigure udev or disable AutoAddDevices.
[    62.211] (II) Loader magic: 0x7f6d20
[    62.211] (II) Module ABI versions:
[    62.211]    X.Org ANSI C Emulation: 0.4
[    62.211]    X.Org Video Driver: 14.1
[    62.211]    X.Org XInput driver : 19.1
[    62.211]    X.Org Server Extension : 7.0
[    62.211] (II) xfree86: Adding drm device (/dev/dri/card0)
[    62.214] (--) PCI:*(0:1:0:0) 10de:124d:1028:0570 rev 161, Mem @ 0xd4000000/33554432, 0xc0000000/268435456, 0xd0000000/67108864, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[    62.214] (II) Open ACPI successful (/var/run/acpid.socket)
[    62.215] Initializing built-in extension Generic Event Extension
[    62.215] Initializing built-in extension SHAPE
[    62.215] Initializing built-in extension MIT-SHM
[    62.216] Initializing built-in extension XInputExtension
[    62.216] Initializing built-in extension XTEST
[    62.216] Initializing built-in extension BIG-REQUESTS
[    62.216] Initializing built-in extension SYNC
[    62.217] Initializing built-in extension XKEYBOARD
[    62.217] Initializing built-in extension XC-MISC
[    62.217] Initializing built-in extension XINERAMA
[    62.217] Initializing built-in extension XFIXES
[    62.218] Initializing built-in extension RENDER
[    62.218] Initializing built-in extension RANDR
[    62.218] Initializing built-in extension COMPOSITE
[    62.218] Initializing built-in extension DAMAGE
[    62.218] Initializing built-in extension MIT-SCREEN-SAVER
[    62.219] Initializing built-in extension DOUBLE-BUFFER
[    62.219] Initializing built-in extension RECORD
[    62.220] Initializing built-in extension DPMS
[    62.221] Initializing built-in extension X-Resource
[    62.221] Initializing built-in extension XVideo
[    62.221] Initializing built-in extension XVideo-MotionCompensation
[    62.221] Initializing built-in extension XFree86-VidModeExtension
[    62.222] Initializing built-in extension XFree86-DGA
[    62.222] Initializing built-in extension XFree86-DRI
[    62.222] Initializing built-in extension DRI2
[    62.222] (II) LoadModule: "glx"
[    62.224] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[    63.109] (II) Module glx: vendor="NVIDIA Corporation"
[    63.109]    compiled for 4.0.2, module version = 1.0.0
[    63.109]    Module class: X.Org Server Extension
[    63.109] (II) NVIDIA GLX Module  325.15  Wed Jul 31 18:12:00 PDT 2013
[    63.115] Loading extension GLX
[    63.115] (II) LoadModule: "nvidia"
[    63.126] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[    63.202] (II) Module nvidia: vendor="NVIDIA Corporation"
[    63.202]    compiled for 4.0.2, module version = 1.0.0
[    63.202]    Module class: X.Org Video Driver
[    63.211] (II) NVIDIA dlloader X Driver  325.15  Wed Jul 31 17:50:57 PDT 2013
[    63.211] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    63.213] (--) using VT number 7
[    63.228] (II) Loading sub module "fb"
[    63.228] (II) LoadModule: "fb"
[    63.229] (II) Loading /usr/lib64/xorg/modules/libfb.so
[    63.242] (II) Module fb: vendor="X.Org Foundation"
[    63.242]    compiled for 1.14.3, module version = 1.0.0
[    63.242]    ABI class: X.Org ANSI C Emulation, version 0.4
[    63.242] (WW) Unresolved symbol: fbGetGCPrivateKey
[    63.242] (II) Loading sub module "wfb"
[    63.242] (II) LoadModule: "wfb"
[    63.243] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[    63.250] (II) Module wfb: vendor="X.Org Foundation"
[    63.250]    compiled for 1.14.3, module version = 1.0.0
[    63.250]    ABI class: X.Org ANSI C Emulation, version 0.4
[    63.250] (II) Loading sub module "shadow"
[    63.250] (II) LoadModule: "shadow"
[    63.251] (II) Loading /usr/lib64/xorg/modules/libshadow.so
[    63.258] (II) Module shadow: vendor="X.Org Foundation"
[    63.258]    compiled for 1.14.3, module version = 1.1.0
[    63.258]    ABI class: X.Org ANSI C Emulation, version 0.4
[    63.258] (II) Loading sub module "ramdac"
[    63.258] (II) LoadModule: "ramdac"
[    63.258] (II) Module "ramdac" already built-in
[    63.263] (II) NVIDIA(0): Creating default Display subsection in Screen section
   "Default Screen Section" for depth/fbbpp 24/32
[    63.263] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    63.263] (==) NVIDIA(0): RGB weight 888
[    63.263] (==) NVIDIA(0): Default visual is TrueColor
[    63.263] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    63.263] (**) NVIDIA(0): Enabling 2D acceleration
[    63.883] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[    63.884] (II) NVIDIA(0): NVIDIA GPU GeForce GT 555M (GF116) at PCI:1:0:0 (GPU-0)
[    63.884] (--) NVIDIA(0): Memory: 3145728 kBytes
[    63.884] (--) NVIDIA(0): VideoBIOS: 70.26.40.00.05
[    63.884] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    64.104] (--) NVIDIA(0): Valid display device(s) on GeForce GT 555M at PCI:1:0:0
[    64.104] (--) NVIDIA(0):     DFP-0
[    64.104] (--) NVIDIA(0):     DFP-1
[    64.104] (--) NVIDIA(0):     LGD (DFP-2) (boot, connected)
[    64.104] (--) NVIDIA(0):     DFP-3
[    64.104] (--) NVIDIA(0): DFP-0: 165.0 MHz maximum pixel clock
[    64.104] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[    64.104] (--) NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
[    64.104] (--) NVIDIA(0): DFP-1: Internal Single Link TMDS
[    64.104] (--) NVIDIA(0): LGD (DFP-2): 480.0 MHz maximum pixel clock
[    64.104] (--) NVIDIA(0): LGD (DFP-2): Internal DisplayPort
[    64.104] (--) NVIDIA(0): DFP-3: 480.0 MHz maximum pixel clock
[    64.104] (--) NVIDIA(0): DFP-3: Internal DisplayPort
[    64.104] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[    64.104] (**) NVIDIA(0):     device LGD (DFP-2) (Using EDID frequencies has been
[    64.104] (**) NVIDIA(0):     enabled on all display devices.)
[    65.136] (==) NVIDIA(0):
[    65.136] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    65.136] (==) NVIDIA(0):     will be used as the requested mode.
[    65.136] (II) NVIDIA(0): Validated MetaModes:
[    65.136] (II) NVIDIA(0):     "DFP-2:nvidia-auto-select{}"
[    65.136] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[    65.152] (--) NVIDIA(0): DPI set to (128, 130); computed from "UseEdidDpi" X config
[    65.152] (--) NVIDIA(0):     option
[    65.152] (--) Depth 24 pixmap format is 32 bpp
[    65.152] (II) NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
[    65.152] (II) NVIDIA:     access.
[    66.293] (II) NVIDIA(0): Setting mode "DFP-2:nvidia-auto-select{}"
[    67.493] Loading extension NV-GLX
[    67.568] (==) NVIDIA(0): Disabling shared memory pixmaps
[    67.568] (==) NVIDIA(0): Backing store disabled
[    67.568] (==) NVIDIA(0): Silken mouse enabled
[    67.576] (==) NVIDIA(0): DPMS enabled
[    67.576] Loading extension NV-CONTROL
[    67.576] Loading extension XINERAMA
[    67.576] (II) Loading sub module "dri2"
[    67.576] (II) LoadModule: "dri2"
[    67.576] (II) Module "dri2" already built-in
[    67.576] (II) NVIDIA(0): [DRI2] Setup complete
[    67.576] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    67.576] (--) RandR disabled
[    67.583] (II) Initializing extension GLX
[    68.054] (II) config/udev: Adding input device Power Button (/dev/input/event5)
[    68.054] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    68.054] (**) Power Button: Applying InputClass "keyboard-all"
[    68.054] (II) LoadModule: "evdev"
[    68.054] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[    68.073] (II) Module evdev: vendor="X.Org Foundation"
[    68.073]    compiled for 1.14.3, module version = 2.8.2
[    68.073]    Module class: X.Org XInput Driver
[    68.073]    ABI class: X.Org XInput driver, version 19.1
[    68.073] (II) Using input driver 'evdev' for 'Power Button'
[    68.073] (**) Power Button: always reports core events
[    68.074] (**) evdev: Power Button: Device: "/dev/input/event5"
[    68.074] (--) evdev: Power Button: Vendor 0 Product 0x1
[    68.074] (--) evdev: Power Button: Found keys
[    68.074] (II) evdev: Power Button: Configuring as keyboard
[    68.074] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input5/event5"
[    68.074] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    68.074] (**) Option "xkb_rules" "evdev"
[    68.074] (**) Option "xkb_model" "pc104"
[    68.074] (**) Option "xkb_layout" "us"
[    68.074] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    68.108] (II) config/udev: Adding input device Video Bus (/dev/input/event7)
[    68.108] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    68.108] (**) Video Bus: Applying InputClass "keyboard-all"
[    68.108] (II) Using input driver 'evdev' for 'Video Bus'
[    68.108] (**) Video Bus: always reports core events
[    68.108] (**) evdev: Video Bus: Device: "/dev/input/event7"
[    68.108] (--) evdev: Video Bus: Vendor 0 Product 0x6
[    68.108] (--) evdev: Video Bus: Found keys
[    68.108] (II) evdev: Video Bus: Configuring as keyboard
[    68.108] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/device:2c/LNXVIDEO:00/input/input7/event7"
[    68.108] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[    68.108] (**) Option "xkb_rules" "evdev"
[    68.108] (**) Option "xkb_model" "pc104"
[    68.108] (**) Option "xkb_layout" "us"
[    68.108] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    68.109] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    68.109] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    68.109] (**) Power Button: Applying InputClass "keyboard-all"
[    68.109] (II) Using input driver 'evdev' for 'Power Button'
[    68.109] (**) Power Button: always reports core events
[    68.109] (**) evdev: Power Button: Device: "/dev/input/event2"
[    68.109] (--) evdev: Power Button: Vendor 0 Product 0x1
[    68.109] (--) evdev: Power Button: Found keys
[    68.109] (II) evdev: Power Button: Configuring as keyboard
[    68.109] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input2/event2"
[    68.109] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[    68.109] (**) Option "xkb_rules" "evdev"
[    68.109] (**) Option "xkb_model" "pc104"
[    68.109] (**) Option "xkb_layout" "us"
[    68.109] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    68.110] (II) config/udev: Adding input device Lid Switch (/dev/input/event4)
[    68.110] (II) No input driver specified, ignoring this device.
[    68.110] (II) This device may have been added with another device file.
[    68.110] (II) config/udev: Adding input device Sleep Button (/dev/input/event3)
[    68.110] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    68.110] (**) Sleep Button: Applying InputClass "keyboard-all"
[    68.110] (II) Using input driver 'evdev' for 'Sleep Button'
[    68.110] (**) Sleep Button: always reports core events
[    68.110] (**) evdev: Sleep Button: Device: "/dev/input/event3"
[    68.110] (--) evdev: Sleep Button: Vendor 0 Product 0x3
[    68.110] (--) evdev: Sleep Button: Found keys
[    68.110] (II) evdev: Sleep Button: Configuring as keyboard
[    68.110] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input3/event3"
[    68.110] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[    68.110] (**) Option "xkb_rules" "evdev"
[    68.110] (**) Option "xkb_model" "pc104"
[    68.110] (**) Option "xkb_layout" "us"
[    68.110] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    68.111] (II) config/udev: Adding drm device (/dev/dri/card0)
[    68.111] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event12)
[    68.111] (II) No input driver specified, ignoring this device.
[    68.111] (II) This device may have been added with another device file.
[    68.111] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event13)
[    68.112] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event14)
[    68.112] (II) No input driver specified, ignoring this device.
[    68.112] (II) This device may have been added with another device file.
[    68.112] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event15)
[    68.112] (II) config/udev: Adding input device Laptop_Integrated_Webcam_2HDM (/dev/input/event17)
[    68.112] (**) Laptop_Integrated_Webcam_2HDM: Applying InputClass "evdev keyboard catchall"
[    68.112] (**) Laptop_Integrated_Webcam_2HDM: Applying InputClass "keyboard-all"
[    68.112] (II) Using input driver 'evdev' for 'Laptop_Integrated_Webcam_2HDM'
[    68.112] (**) Laptop_Integrated_Webcam_2HDM: always reports core events
[    68.112] (**) evdev: Laptop_Integrated_Webcam_2HDM: Device: "/dev/input/event17"
[    68.112] (--) evdev: Laptop_Integrated_Webcam_2HDM: Vendor 0x408 Product 0x2fb1
[    68.112] (--) evdev: Laptop_Integrated_Webcam_2HDM: Found keys
[    68.112] (II) evdev: Laptop_Integrated_Webcam_2HDM: Configuring as keyboard
[    68.112] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input17/event17"
[    68.112] (II) XINPUT: Adding extended input device "Laptop_Integrated_Webcam_2HDM" (type: KEYBOARD, id 10)
[    68.112] (**) Option "xkb_rules" "evdev"
[    68.112] (**) Option "xkb_model" "pc104"
[    68.112] (**) Option "xkb_layout" "us"
[    68.112] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    68.113] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event10)
[    68.113] (II) No input driver specified, ignoring this device.
[    68.113] (II) This device may have been added with another device file.
[    68.113] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event11)
[    68.114] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event9)
[    68.114] (II) No input driver specified, ignoring this device.
[    68.114] (II) This device may have been added with another device file.
[    68.114] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/event16)
[    68.114] (**) Logitech USB Optical Mouse: Applying InputClass "evdev pointer catchall"
[    68.114] (II) Using input driver 'evdev' for 'Logitech USB Optical Mouse'
[    68.114] (**) Logitech USB Optical Mouse: always reports core events
[    68.114] (**) evdev: Logitech USB Optical Mouse: Device: "/dev/input/event16"
[    68.114] (--) evdev: Logitech USB Optical Mouse: Vendor 0x46d Product 0xc06c
[    68.114] (--) evdev: Logitech USB Optical Mouse: Found 3 mouse buttons
[    68.114] (--) evdev: Logitech USB Optical Mouse: Found scroll wheel(s)
[    68.114] (--) evdev: Logitech USB Optical Mouse: Found relative axes
[    68.114] (--) evdev: Logitech USB Optical Mouse: Found x and y relative axes
[    68.114] (II) evdev: Logitech USB Optical Mouse: Configuring as mouse
[    68.114] (II) evdev: Logitech USB Optical Mouse: Adding scrollwheel support
[    68.114] (**) evdev: Logitech USB Optical Mouse: YAxisMapping: buttons 4 and 5
[    68.114] (**) evdev: Logitech USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    68.114] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.1/2-1.1:1.0/input/input16/event16"
[    68.114] (II) XINPUT: Adding extended input device "Logitech USB Optical Mouse" (type: MOUSE, id 11)
[    68.114] (II) evdev: Logitech USB Optical Mouse: initialized for relative axes.
[    68.115] (**) Logitech USB Optical Mouse: (accel) keeping acceleration scheme 1
[    68.115] (**) Logitech USB Optical Mouse: (accel) acceleration profile 0
[    68.115] (**) Logitech USB Optical Mouse: (accel) acceleration factor: 2.000
[    68.115] (**) Logitech USB Optical Mouse: (accel) acceleration threshold: 4
[    68.115] (II) config/udev: Adding input device Logitech USB Optical Mouse (/dev/input/mouse1)
[    68.115] (II) No input driver specified, ignoring this device.
[    68.115] (II) This device may have been added with another device file.
[    68.115] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event1)
[    68.115] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    68.115] (**) AT Translated Set 2 keyboard: Applying InputClass "keyboard-all"
[    68.115] (II) Using input driver 'evdev' for 'AT Translated Set 2 keyboard'
[    68.115] (**) AT Translated Set 2 keyboard: always reports core events
[    68.116] (**) evdev: AT Translated Set 2 keyboard: Device: "/dev/input/event1"
[    68.116] (--) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[    68.116] (--) evdev: AT Translated Set 2 keyboard: Found keys
[    68.116] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[    68.116] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input1/event1"
[    68.116] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[    68.116] (**) Option "xkb_rules" "evdev"
[    68.116] (**) Option "xkb_model" "pc104"
[    68.116] (**) Option "xkb_layout" "us"
[    68.116] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    68.116] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event8)
[    68.116] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[    68.116] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[    68.116] (II) LoadModule: "synaptics"
[    68.117] (II) Loading /usr/lib64/xorg/modules/input/synaptics_drv.so
[    68.126] (II) Module synaptics: vendor="X.Org Foundation"
[    68.127]    compiled for 1.14.2, module version = 1.7.1
[    68.127]    Module class: X.Org XInput Driver
[    68.127]    ABI class: X.Org XInput driver, version 19.1
[    68.127] (II) Using input driver 'synaptics' for 'SynPS/2 Synaptics TouchPad'
[    68.127] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    68.127] (**) Option "Device" "/dev/input/event8"
[    68.147] (II) synaptics: SynPS/2 Synaptics TouchPad: ignoring touch events for semi-multitouch device
[    68.147] (--) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5398 (res 42)
[    68.147] (--) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 4728 (res 70)
[    68.147] (--) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[    68.147] (--) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[    68.147] (--) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right double triple
[    68.147] (--) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[    68.147] (**) Option "TapButton1" "1"
[    68.147] (**) Option "TapButton2" "2"
[    68.147] (**) Option "TapButton3" "3"
[    68.147] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    68.147] (**) SynPS/2 Synaptics TouchPad: always reports core events
[    68.157] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input8/event8"
[    68.157] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 13)
[    68.157] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[    68.157] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) MaxSpeed is now 1.75
[    68.157] (**) synaptics: SynPS/2 Synaptics TouchPad: (accel) AccelFactor is now 0.039
[    68.157] (**) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[    68.157] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[    68.157] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[    68.157] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[    68.157] (--) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[    68.158] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[    68.158] (II) No input driver specified, ignoring this device.
[    68.158] (II) This device may have been added with another device file.
[    68.159] (II) config/udev: Adding input device Speakup (/dev/input/event0)
[    68.159] (**) Speakup: Applying InputClass "evdev keyboard catchall"
[    68.159] (**) Speakup: Applying InputClass "keyboard-all"
[    68.159] (II) Using input driver 'evdev' for 'Speakup'
[    68.159] (**) Speakup: always reports core events
[    68.159] (**) evdev: Speakup: Device: "/dev/input/event0"
[    68.159] (--) evdev: Speakup: Vendor 0 Product 0
[    68.159] (--) evdev: Speakup: Found keys
[    68.159] (II) evdev: Speakup: Configuring as keyboard
[    68.159] (**) Option "config_info" "udev:/sys/devices/virtual/input/input0/event0"
[    68.159] (II) XINPUT: Adding extended input device "Speakup" (type: KEYBOARD, id 14)
[    68.159] (**) Option "xkb_rules" "evdev"
[    68.159] (**) Option "xkb_model" "pc104"
[    68.159] (**) Option "xkb_layout" "us"
[    68.159] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    68.160] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event6)
[    68.160] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    68.160] (**) Dell WMI hotkeys: Applying InputClass "keyboard-all"
[    68.160] (II) Using input driver 'evdev' for 'Dell WMI hotkeys'
[    68.160] (**) Dell WMI hotkeys: always reports core events
[    68.160] (**) evdev: Dell WMI hotkeys: Device: "/dev/input/event6"
[    68.160] (--) evdev: Dell WMI hotkeys: Vendor 0 Product 0
[    68.160] (--) evdev: Dell WMI hotkeys: Found keys
[    68.160] (II) evdev: Dell WMI hotkeys: Configuring as keyboard
[    68.160] (**) Option "config_info" "udev:/sys/devices/virtual/input/input6/event6"
[    68.160] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 15)
[    68.160] (**) Option "xkb_rules" "evdev"
[    68.160] (**) Option "xkb_model" "pc104"
[    68.160] (**) Option "xkb_layout" "us"
[    68.160] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
Pero quando vado in System settings--Desktop effects e cerco di abilitare le finestre tremolanti mi da errore che e richiesto OpenGL.
Prima ho cancellato xorg.conf..
Non ho xorg.conf in /etc/X11 e anche /etc/X11/xorg.conf.d e vuoto.
Devo creare xorg.conf per abilitare OpenGL? o mi sto confondendo?
varjag
Messaggioda varjag » mar nov 12, 2013 17:22
glxinfo
name of display: :0
    GLX_ARB_create_context, GLX_ARB_create_context_profile,
    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
    GLX_ARB_multisample, GLX_EXT_buffer_age,
    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
    GLX_EXT_framebuffer_sRGB, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_NV_float_buffer, GLX_NV_multisample_coverage, GLX_SGIX_fbconfig,
    GLX_SGIX_pbuffer, GLX_SGI_swap_control, GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_import_context, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
    GLX_NV_copy_image, GLX_NV_float_buffer, GLX_NV_multisample_coverage,
    GLX_NV_present_video, GLX_NV_swap_group, GLX_NV_video_capture,
    GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX version: 1.4
GLX extensions:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GT 555M/PCIe/SSE2
OpenGL core profile version string: 4.3.0 NVIDIA 325.15
OpenGL core profile shading language version string: 4.30 NVIDIA via Cg compiler
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
    GL_AMD_multi_draw_indirect, GL_ARB_ES2_compatibility,
    GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,
    GL_ARB_blend_func_extended, GL_ARB_clear_buffer_object,
    GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_compute_shader, GL_ARB_conservative_depth, GL_ARB_copy_buffer,
    GL_ARB_copy_image, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
    GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_draw_buffers,
    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
    GL_ARB_draw_indirect, GL_ARB_draw_instanced,
    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
    GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
    GL_ARB_geometry_shader4, GL_ARB_get_program_binary, GL_ARB_gpu_shader5,
    GL_ARB_gpu_shader_fp64, GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
    GL_ARB_imaging, GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
    GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
    GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range,
    GL_ARB_multi_draw_indirect, GL_ARB_multisample, GL_ARB_multitexture,
    GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
    GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
    GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
    GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
    GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
    GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counters,
    GL_ARB_shader_bit_encoding, GL_ARB_shader_image_load_store,
    GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision,
    GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
    GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
    GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
    GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_stencil_texturing,
    GL_ARB_sync, GL_ARB_tessellation_shader, GL_ARB_texture_border_clamp,
    GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
    GL_ARB_texture_buffer_range, GL_ARB_texture_compression,
    GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
    GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
    GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
    GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
    GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirrored_repeat, GL_ARB_texture_multisample,
    GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
    GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
    GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_storage,
    GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
    GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
    GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
    GL_ARB_transpose_matrix, GL_ARB_uniform_buffer_object,
    GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
    GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_viewport_array,
    GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
    GL_ATI_texture_mirror_once, GL_EXTX_framebuffer_mixed_formats,
    GL_EXT_Cg_shader, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_bindable_uniform,
    GL_EXT_blend_color, GL_EXT_blend_equation_separate,
    GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
    GL_EXT_compiled_vertex_array, GL_EXT_depth_bounds_test,
    GL_EXT_direct_state_access, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
    GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
    GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
    GL_EXT_geometry_shader4, GL_EXT_gpu_program_parameters,
    GL_EXT_gpu_shader4, GL_EXT_import_sync_object, GL_EXT_multi_draw_arrays,
    GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
    GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_shader_objects, GL_EXT_separate_specular_color,
    GL_EXT_shader_image_load_store, GL_EXT_shadow_funcs,
    GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
    GL_EXT_texture_array, GL_EXT_texture_buffer_object,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_latc,
    GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
    GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
    GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
    GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
    GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
    GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_timer_query,
    GL_EXT_transform_feedback2, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
    GL_EXT_vertex_attrib_64bit, GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_KHR_debug, GL_KTX_buffer_region,
    GL_NVX_conditional_render, GL_NVX_gpu_memory_info,
    GL_NV_ES1_1_compatibility, GL_NV_bindless_multi_draw_indirect,
    GL_NV_blend_square, GL_NV_compute_program5, GL_NV_conditional_render,
    GL_NV_copy_depth_to_color, GL_NV_copy_image, GL_NV_depth_buffer_float,
    GL_NV_depth_clamp, GL_NV_draw_texture, GL_NV_explicit_multisample,
    GL_NV_fence, GL_NV_float_buffer, GL_NV_fog_distance,
    GL_NV_fragment_program, GL_NV_fragment_program2,
    GL_NV_fragment_program_option, GL_NV_framebuffer_multisample_coverage,
    GL_NV_geometry_shader4, GL_NV_gpu_program4, GL_NV_gpu_program4_1,
    GL_NV_gpu_program5, GL_NV_gpu_program5_mem_extended,
    GL_NV_gpu_program_fp64, GL_NV_gpu_shader5, GL_NV_half_float,
    GL_NV_light_max_exponent, GL_NV_multisample_coverage,
    GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
    GL_NV_packed_depth_stencil, GL_NV_parameter_buffer_object,
    GL_NV_parameter_buffer_object2, GL_NV_path_rendering,
    GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_primitive_restart,
    GL_NV_register_combiners, GL_NV_register_combiners2,
    GL_NV_shader_atomic_counters, GL_NV_shader_atomic_float,
    GL_NV_shader_buffer_load, GL_NV_shader_storage_buffer_object,
    GL_NV_texgen_reflection, GL_NV_texture_barrier,
    GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
    GL_NV_texture_expand_normal, GL_NV_texture_multisample,
    GL_NV_texture_rectangle, GL_NV_texture_shader, GL_NV_texture_shader2,
    GL_NV_texture_shader3, GL_NV_transform_feedback,
    GL_NV_transform_feedback2, GL_NV_vdpau_interop, GL_NV_vertex_array_range,
    GL_NV_vertex_array_range2, GL_NV_vertex_attrib_integer_64bit,
    GL_NV_vertex_buffer_unified_memory, GL_NV_vertex_program,
    GL_NV_vertex_program1_1, GL_NV_vertex_program2,
    GL_NV_vertex_program2_option, GL_NV_vertex_program3, GL_S3_s3tc,
    GL_SGIS_generate_mipmap, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
    GL_SGIX_shadow, GL_SUN_slice_accum
OpenGL version string: 4.3.0 NVIDIA 325.15
OpenGL shading language version string: 4.30 NVIDIA via Cg compiler
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
    GL_ARB_color_buffer_float, GL_ARB_compatibility,
    GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
    GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
    GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
    GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
    GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
    GL_ARB_draw_instanced, GL_ARB_explicit_attrib_location,
    GL_ARB_explicit_uniform_location, GL_ARB_fragment_coord_conventions,
    GL_ARB_fragment_layer_viewport, GL_ARB_fragment_program,
    GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
    GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object,
    GL_ARB_framebuffer_sRGB, GL_ARB_geometry_shader4,
    GL_ARB_get_program_binary, GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64,
    GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_imaging,
228 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x021 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x022 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x024 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x025 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x026 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x027 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x028 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x029 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x02a 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x02b 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x02c 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x02d 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x02e 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x02f 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x030 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x031 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x032 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x033 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x034 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x035 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x036 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x037 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x038 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x039 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x03a 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x03b 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x03c 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x03d 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x03e 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x03f 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x040 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x041 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x042 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x043 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x044 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x045 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x046 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x047 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x048 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x049 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x04a 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x04b 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x04c 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x04d 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x04e 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x04f 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x050 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x051 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x052 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x053 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x054 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x055 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x056 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x057 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x058 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x059 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x05a 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x05b 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x05c 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x05d 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x05e 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x05f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x060 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x061 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x062 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x063 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x064 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x065 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x066 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x067 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x068 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x069 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x06a 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x06b 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x06c 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x06d 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x06e 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x06f 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x070 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x071 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x072 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x073 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x074 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x075 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x076 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x077 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x078 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x079 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x07a 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x07b 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x07c 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x07d 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x07e 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x07f 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x080 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x081 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x082 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x083 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x084 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x085 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x086 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x087 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x088 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x089 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x08a 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x08b 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x08c 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x08d 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x08e 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x08f 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x090 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x091 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x092 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x093 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x094 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x095 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x096 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x097 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x098 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x099 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x09a 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x09b 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x09c 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x09d 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x09e 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x09f 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0a0 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0a1 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0a2 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0a3 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0a4 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0a5 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0a6 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0a7 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0a8 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0a9 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0aa 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0ab 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0ac 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0ad 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0ae 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0af 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0b0 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0b1 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0b2 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x0b3 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x0b4 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x0b5 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x0b6 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x0b7 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x0b8 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x0b9 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x023 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x0ba 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x0bb 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x0bc 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x0bd 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x0be 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x0bf 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x0c0 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x0c1 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x0c2 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x0c3 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x0c4 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x0c5 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x0c6 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x0c7 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x0c8 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x0c9 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x0ca 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x0cb 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x0cc 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x0cd 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x0ce 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x0cf 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x0d0 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x0d1 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x0d2 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x0d3 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x0d4 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x0d5 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0d6 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0d7 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0d8 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0d9 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0da 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0db 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0dc 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0dd 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0de 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0df 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0e0 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0e1 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0e2 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0e3 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0e4 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0e5 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0e6 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0e7 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0e8 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0e9 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0ea 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0eb 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0ec 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x0ed 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0ee 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0ef 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0f0 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x0f1 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0f2 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0f3 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0f4 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0f5 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0f6 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0f7 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0f8 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x0f9 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0fa 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0fb 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0fc 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x0fd 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x0fe 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x0ff 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x100 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x101 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x102 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x103 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x104 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
311 GLXFBConfigs:
0x105 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x106 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x107 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x108 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x109 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x10a 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x10b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x10c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x10d 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x10e 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x10f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x110 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x111 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x112 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x113 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x114 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x115 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x116 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x117 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x118 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x119 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x11a 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x11b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x11c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x11d 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x11e 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x11f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x120 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x121 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x122 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x123 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x124 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x125 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x126 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x127 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x128 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x129 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x12a 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x12b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x12c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x12d 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x12e 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x12f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x130 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x131 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x132 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x133 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x134 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x135 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x136 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x137 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x138 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x139 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x13a 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x13b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x13c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x13d 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x13e 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x13f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x140 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x141 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x142 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x143 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x144 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x145 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x146 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x147 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x148 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x149 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x14a 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x14b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x14c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x14d 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x14e 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x14f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x150 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x151 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x152 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x153 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x154 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x155 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x156 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x157 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x158 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x159 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x15a 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x15b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x15c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x15d 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x15e 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x15f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x160 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x161 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x162 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x163 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x164 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x165 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x166 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x167 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x168 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x169 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x16a 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x16b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x16c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x16d 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x16e 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x16f 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x170 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x171 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x172 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x173 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x174 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x175 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x176 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x177 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x178 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x179 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x17a 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x17b 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x17c 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x17d 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x17e 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x17f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x180 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x181 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x182 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x183 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x184 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x185 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x186 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x187 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x188 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x189 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x18a 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x18b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x18c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x18d 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x18e 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x18f 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x190 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x191 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x192 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x193 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x194 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x195 24 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x196 24 dc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x197 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x198 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x199 24 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x19a 24 dc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x19b 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x19c 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x19d 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x19e 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x19f 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x1a0 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x1a1 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x1a2 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x1a3 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x1a4 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x1a5 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x1a6 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x1a7 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x1a8 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x1a9 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x1aa 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x1ab 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x1ac 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x1ad 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x1ae 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 Ncon
0x1af 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x1b0 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 Ncon
0x1b1 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x1b2 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x1b3 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x1b4 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x1b5 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x1b6 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 Ncon
0x1b7 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x1b8 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 Ncon
0x1b9 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x1ba 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x1bb 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1bc 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1bd 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x1be 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x1bf 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1c0 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1c1 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x1c2 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x1c3 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1c4 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1c5 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x1c6 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x1c7 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1c8 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1c9 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x1ca 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x1cb 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1cc 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1cd 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1ce 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1cf 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x1d0 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 Ncon
0x1d1 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1d2 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1d3 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1d4 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 Ncon
0x1d5 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x1d6 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x1d7 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1d8 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1d9 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1da 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1db 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x1dc 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 Ncon
0x1dd 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1de 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1df 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1e0 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 Ncon
0x1e1 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x1e2 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x1e3 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x1e4 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 32 1 Ncon
0x1e5 32 tc  0  32  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x1e6 32 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x1e7 32 tc  0  32  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x1e8 32 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 32 1 Ncon
0x1e9  0 sg  0  16  0 r  y .   5  6  5  0 .  .  4 16  0 16 16 16 16  0 0 None
0x1ea  0 sg  0  16  0 r  . .   5  6  5  0 .  .  4 16  0 16 16 16 16  0 0 None
0x1eb  0 sg  0  16  0 r  y .   5  6  5  0 .  .  4 24  0 16 16 16 16  0 0 None
0x1ec  0 sg  0  16  0 r  . .   5  6  5  0 .  .  4 24  0 16 16 16 16  0 0 None
0x1ed  0 sg  0  16  0 r  y .   5  6  5  0 .  .  4 24  8 16 16 16 16  0 0 None
0x1ee  0 sg  0  16  0 r  . .   5  6  5  0 .  .  4 24  8 16 16 16 16  0 0 None
0x1ef  0 sg  0  16  0 r  y .   5  6  5  0 .  .  4  0  0 16 16 16 16  0 0 None
0x1f0  0 sg  0  16  0 r  . .   5  6  5  0 .  .  4  0  0 16 16 16 16  0 0 None
0x1f1  0 sg  0   0  0 r  . .   0  0  0  0 .  .  4 16  0 16 16 16 16  0 0 None
0x1f2  0 sg  0   0  0 r  . .   0  0  0  0 .  .  4 24  0 16 16 16 16  0 0 None
0x1f3  0 sg  0   0  0 r  . .   0  0  0  0 .  .  4 24  8 16 16 16 16  0 0 None
0x1f4  0 sg  0  32  0 r  . .  16 16  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f5  0 sg  0  32  0    . .  16 16  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f6  0 sg  0  32  0 r  y .  16 16  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f7  0 sg  0  32  0    y .  16 16  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f8  0 sg  0  32  0 r  . .  32  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f9  0 sg  0  32  0    . .  32  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1fa  0 sg  0  32  0 r  y .  32  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1fb  0 sg  0  32  0    y .  32  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1fc  0 sg  0  64  0 r  . .  16 16 16 16 f  .  4  0  0 16 16 16 16  0 0 None
0x1fd  0 sg  0  64  0    . .  16 16 16 16 f  .  4  0  0 16 16 16 16  0 0 None
0x1fe  0 sg  0  64  0 r  y .  16 16 16 16 f  .  4  0  0 16 16 16 16  0 0 None
0x1ff  0 sg  0  64  0    y .  16 16 16 16 f  .  4  0  0 16 16 16 16  0 0 None
0x200  0 sg  0 128  0 r  . .  32 32 32 32 f  .  4  0  0 16 16 16 16  0 0 None
0x201  0 sg  0 128  0    . .  32 32 32 32 f  .  4  0  0 16 16 16 16  0 0 None
0x202  0 sg  0 128  0 r  y .  32 32 32 32 f  .  4  0  0 16 16 16 16  0 0 None
0x203  0 sg  0 128  0    y .  32 32 32 32 f  .  4  0  0 16 16 16 16  0 0 None
0x204  0 sg  0  32  0 r  . .  16 16  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x205  0 sg  0  32  0    . .  16 16  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x206  0 sg  0  32  0 r  y .  16 16  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x207  0 sg  0  32  0    y .  16 16  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x208  0 sg  0  32  0 r  . .  16 16  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x209  0 sg  0  32  0    . .  16 16  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x20a  0 sg  0  32  0 r  y .  16 16  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x20b  0 sg  0  32  0    y .  16 16  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x20c  0 sg  0  32  0 r  . .  32  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x20d  0 sg  0  32  0    . .  32  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x20e  0 sg  0  32  0 r  y .  32  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x20f  0 sg  0  32  0    y .  32  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x210  0 sg  0  32  0 r  . .  32  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x211  0 sg  0  32  0    . .  32  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x212  0 sg  0  32  0 r  y .  32  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x213  0 sg  0  32  0    y .  32  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x214  0 sg  0  64  0 r  . .  16 16 16 16 f  .  4 24  0 16 16 16 16  0 0 None
0x215  0 sg  0  64  0    . .  16 16 16 16 f  .  4 24  0 16 16 16 16  0 0 None
0x216  0 sg  0  64  0 r  y .  16 16 16 16 f  .  4 24  0 16 16 16 16  0 0 None
0x217  0 sg  0  64  0    y .  16 16 16 16 f  .  4 24  0 16 16 16 16  0 0 None
0x218  0 sg  0  64  0 r  . .  16 16 16 16 f  .  4 24  8 16 16 16 16  0 0 None
0x219  0 sg  0  64  0    . .  16 16 16 16 f  .  4 24  8 16 16 16 16  0 0 None
0x21a  0 sg  0  64  0 r  y .  16 16 16 16 f  .  4 24  8 16 16 16 16  0 0 None
0x21b  0 sg  0  64  0    y .  16 16 16 16 f  .  4 24  8 16 16 16 16  0 0 None
0x21c  0 sg  0 128  0 r  . .  32 32 32 32 f  .  4 24  0 16 16 16 16  0 0 None
0x21d  0 sg  0 128  0    . .  32 32 32 32 f  .  4 24  0 16 16 16 16  0 0 None
0x21e  0 sg  0 128  0 r  y .  32 32 32 32 f  .  4 24  0 16 16 16 16  0 0 None
0x21f  0 sg  0 128  0    y .  32 32 32 32 f  .  4 24  0 16 16 16 16  0 0 None
0x220  0 sg  0 128  0 r  . .  32 32 32 32 f  .  4 24  8 16 16 16 16  0 0 None
0x221  0 sg  0 128  0    . .  32 32 32 32 f  .  4 24  8 16 16 16 16  0 0 None
0x222  0 sg  0 128  0 r  y .  32 32 32 32 f  .  4 24  8 16 16 16 16  0 0 None
0x223  0 sg  0 128  0    y .  32 32 32 32 f  .  4 24  8 16 16 16 16  0 0 None
0x224  0 sg  0  16  0 r  . .  16  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x225  0 sg  0  16  0    . .  16  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x226  0 sg  0  16  0 r  y .  16  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x227  0 sg  0  16  0    y .  16  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x228  0 sg  0  64  0 r  . .  32 32  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x229  0 sg  0  64  0    . .  32 32  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x22a  0 sg  0  64  0 r  y .  32 32  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x22b  0 sg  0  64  0    y .  32 32  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x22c  0 sg  0  16  0 r  . .  16  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x22d  0 sg  0  16  0    . .  16  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x22e  0 sg  0  16  0 r  y .  16  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x22f  0 sg  0  16  0    y .  16  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x230  0 sg  0  16  0 r  . .  16  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x231  0 sg  0  16  0    . .  16  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x232  0 sg  0  16  0 r  y .  16  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x233  0 sg  0  16  0    y .  16  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x234  0 sg  0  64  0 r  . .  32 32  0  0 f  .  4 24  0 16 16 16 16  0 0 None
bash-4.2$
brg
Kernel: 4.4.38
Desktop: KDE4
Re: Problema con slackware64-14.1 e driver Nvidia
Messaggioda brg » mar nov 12, 2013 17:40
xorg.conf non è più necessario, il programma di configurazione Nvidia (è sotto Impostazioni nel menù di KDE) che dice?
varjag
Messaggioda varjag » mar nov 12, 2013 17:49
stai parlando di Nvidia server settings?
OpenGL/GLX information
GLX information
Direct Rendering: Yes
GLX Extensions: GLX_EXT_visual_info
GLX_SGIX_fbconfig
GLX_SGIX_pbuffer
GLX_SGI_video_sync
GLX_EXT_buffer_age
GLX_ARB_multisample
GLX_NV_float_buffer
Server GLX information
NVIDIA Corporation
Extensions:
GLX_EXT_visual_info
GLX_SGIX_fbconfig
GLX_SGIX_pbuffer
GLX_SGI_video_sync
GLX_EXT_buffer_age
GLX_ARB_multisample
GLX_NV_float_buffer
Client GLX information
NVIDIA Corporation
GLX_ARB_multisample
GLX_EXT_visual_info
GLX_SGI_video_sync
GLX_NV_swap_group
GLX_NV_video_out
GLX_SGIX_fbconfig
GLX_SGIX_pbuffer
GLX_EXT_buffer_age
GLX_NV_float_buffer
GLX_NV_copy_image
OpenGL infomation
NVIDIA Corporation
4.3.0 NVIDIA 325.15
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_debug_output
GL_ARB_depth_clamp
GL_ARB_draw_buffers
GL_ARB_gpu_shader5
GL_ARB_imaging
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_point_sprite
GL_ARB_robustness
GL_ARB_shadow
GL_ARB_sync
GL_ARB_texture_rg
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_S3_s3tc
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_minmax
GL_EXT_Cg_shader
GL_EXT_fog_coord
GL_EXT_gpu_shader4
GL_EXT_packed_float
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_lod
GL_EXT_texture_sRGB
GL_EXT_timer_query
GL_EXT_vertex_array
GL_KHR_debug
GL_NV_blend_square
GL_NV_copy_image
GL_NV_depth_clamp
GL_NV_draw_texture
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_gpu_program4
GL_NV_gpu_program5
GL_NV_gpu_shader5
GL_NV_half_float
GL_NV_point_sprite
GL_NV_vdpau_interop
GL_SGIS_texture_lod
GL_SGIX_shadow
GL_SUN_slice_accum
brg
Kernel: 4.4.38
Desktop: KDE4
Messaggioda brg » mar nov 12, 2013 17:53
Sembra funzionare tutto. Hai guardato, in System settings -> Desktop effects -> Advanced, ci dovrebbero essere le opzioni OpenGL.
