ATI proprietary drivers. Ecco uno SlackBuild !!!
Tanino Rulez
Slackware: 12.1
Kernel: 2.6.24.5
Desktop: Fluxbox
Messaggio da Tanino Rulez »
ho appena installato la slackware, ho seguito la guida ma quando cerco di installare i driver ho il seguente errore
The distribution 'custom-package' is not supported
Removing temporary directory: fglrx-install.lSFjz1
che significa??
edit: risolto
Tanino Rulez
Slackware: 12.1
Kernel: 2.6.24.5
Desktop: Fluxbox
a me nn va continua a darmi
display: :0.0  screen: 0
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.4 (1.5 Mesa 6.5.2)
come faccio??
Tanino Rulez ha scritto:a me nn va continua a darmi
come faccio??
Ma hai una slackware o un porting a 64 bit?
Spina
Tanino Rulez
Slackware: 12.1
Kernel: 2.6.24.5
Desktop: Fluxbox
slack ( grazie per la risposta )
posta l'output del comando:
strace -e open fglrxinfo
Spina
Tanino Rulez
Slackware: 12.1
Kernel: 2.6.24.5
Desktop: Fluxbox
open("/usr/lib/xorg/tls/i686/sse2/libGL.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/xorg/tls/i686/libGL.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/xorg/tls/sse2/libGL.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/xorg/tls/libGL.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/xorg/i686/sse2/libGL.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/xorg/i686/libGL.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/xorg/sse2/libGL.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/xorg/libGL.so.1", O_RDONLY) = 3
open("/usr/lib/xorg/libX11.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY)      = 3
open("/usr/lib/libX11.so.6", O_RDONLY)  = 3
open("/usr/lib/xorg/libXext.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libXext.so.6", O_RDONLY) = 3
open("/usr/lib/xorg/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libc.so.6", O_RDONLY)        = 3
open("/usr/lib/xorg/libpthread.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libpthread.so.0", O_RDONLY)  = 3
open("/usr/lib/xorg/libxcb-xlib.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libxcb-xlib.so.0", O_RDONLY) = 3
open("/usr/lib/xorg/libxcb.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libxcb.so.1", O_RDONLY)  = 3
open("/usr/lib/xorg/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libdl.so.2", O_RDONLY)       = 3
open("/usr/lib/xorg/libXau.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libXau.so.6", O_RDONLY)  = 3
open("/usr/lib/xorg/libXdmcp.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libXdmcp.so.6", O_RDONLY) = 3
open("/root/.Xauthority", O_RDONLY)     = 4
Process 12523 detached
ora posta l'output del comando:
grep libGL /var/log/packages/fglrx-x....
Spina
Tanino Rulez
Slackware: 12.1
Kernel: 2.6.24.5
Desktop: Fluxbox
nessun output mi da
ho dato
grep libGL /var/log/packages/fglrx-x710-8.433-x86-1usr/lib/libGL.so.1.2
Tanino Rulez ha scritto:...usr/lib/libGL.so.1.2
suppongo che l'output sia questo.
mmm è interessante, è mooolto interessante.
Per risolvere il tuo problema mi manca ancora un passo, l'output di:
ls -l /usr/lib/xorg/libGL*
Spina
Tanino Rulez
Slackware: 12.1
Kernel: 2.6.24.5
Desktop: Fluxbox
lrwxrwxrwx 1 root root     26 2007-12-16 19:34 /usr/lib/xorg/libGL.so -> /usr/lib/xorg/libGL.so.1.2
lrwxrwxrwx 1 root root     26 2007-12-16 19:34 /usr/lib/xorg/libGL.so.1 -> /usr/lib/xorg/libGL.so.1.2
-rw-r--r-- 1 root root 679655 2007-12-16 19:34 /usr/lib/xorg/libGL.so.1.2
perchè è interessante? :D
Così ti tengo sulle spine :).
Allora, per risolvere il tuo problema devi:
1) andare nella directory /usr/lib/xorg/
2) copiare (come backup) il file libGL.so.1.2 dove ti pare, magari in /tmp
3) eliminare suddetto file
4) linkare il file ibGL.so.1.2 che è nella directory /usr/lib, con
 ln -s ../ibGL.so.1.2
poi riprova fglrxinfo e dimmi se funziona.
Spina
Tanino Rulez
Slackware: 12.1
Kernel: 2.6.24.5
Desktop: Fluxbox
fglrxinfo: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
Tanino Rulez ha scritto:fglrxinfo: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
Prova, invece del link, a spostare il file
/usr/lib/libGL.so.1.2
nella directory:
/usr/lib/xrog/
Spina
Tanino Rulez
Slackware: 12.1
Kernel: 2.6.24.5
Desktop: Fluxbox
nn c'è il file,c'è 1 collegamento.. è la stessa cosa??
Tanino Rulez ha scritto:nn c'è il file,c'è 1 collegamento.. è la stessa cosa??
No, a cosa punta il collegamento? ls -l /usr/lib/libGL.so.1.2 cosa da?
Spina
