Virtualbox e EFI -RISOLTO
Rama
Slackware: 15.0 x86_64
Desktop: KDE 5.23
Messaggio da Rama »
sistemato tutto, manca solo Virtualbox:
bash-5.1# /sbin/vboxconfig
vboxdrv.sh: Stopping VirtualBox services.
vboxdrv.sh: Starting VirtualBox services.
vboxdrv.sh: Building VirtualBox kernel modules.
vboxdrv.sh: failed: Look at /var/log/vbox-setup.log to find out what went wrong.
There were problems setting up VirtualBox. To re-start the set-up process, run
/sbin/vboxconfig
as root. If your system is using EFI Secure Boot you may need to sign the
kernel modules (vboxdrv, vboxnetflt, vboxnetadp, vboxpci) before you can load
them. Please see your Linux system's documentation for more information.
bash-5.1# modprobe vboxdrv
modprobe: FATAL: Module vboxdrv not found in directory /lib/modules/5.15.19
lo odio sempre più, 'sto EFI;
Ultima modifica di Rama il ven 11 feb 2022, 12:43, modificato 1 volta in totale.
erio
Kernel: 3.0.7
Re: Virtualbox e EFI
Messaggio da erio »
scusa la domanda ma hai il kernel source in src perche ti serve per compilare i moduli di virtualbox,se non ricordo male: efi stavolta e' innocente
 bash-5.1# sh '/usr/src/vboxhost-6.1.97/build_in_tmp'
=== Building 'vboxdrv' module ===
make[1]: ingresso nella directory «/tmp/vbox.0/vboxdrv»
make V= CONFIG_MODULE_SIG= CONFIG_MODULE_SIG_ALL= -C /lib/modules/5.16.8-beny/build M=/tmp/vbox.0/vboxdrv SRCROOT=/tmp/vbox.0/vboxdrv -j6 modules
make[2]: ingresso nella directory «/tmp/vbox.0/vboxdrv»
make[2]: attenzione: -j6 forzata nel submake: disattivazione della modalità jobserver.
  CC [M]  /tmp/vbox.0/vboxdrv/linux/SUPDrv-linux.o
  CC [M]  /tmp/vbox.0/vboxdrv/SUPDrv.o
  CC [M]  /tmp/vbox.0/vboxdrv/SUPDrvGip.o
  CC [M]  /tmp/vbox.0/vboxdrv/SUPDrvSem.o
  CC [M]  /tmp/vbox.0/vboxdrv/SUPDrvTracer.o
  CC [M]  /tmp/vbox.0/vboxdrv/SUPLibAll.o
  CC [M]  /tmp/vbox.0/vboxdrv/common/string/strformatrt.o
  CC [M]  /tmp/vbox.0/vboxdrv/combined-agnostic1.o
  CC [M]  /tmp/vbox.0/vboxdrv/combined-agnostic2.o
/tmp/vbox.0/vboxdrv/SUPDrvTracer.o: warning: objtool: SUPR0TracerFireProbe()+0x7: indirect jump found in RETPOLINE build
  CC [M]  /tmp/vbox.0/vboxdrv/combined-os-specific.o
/tmp/vbox.0/vboxdrv/combined-os-specific.o: warning: objtool: VBoxHost_RTR0MemKernelCopyFrom()+0x15: redundant CLD
/tmp/vbox.0/vboxdrv/combined-os-specific.o: warning: objtool: rtThreadCtxHooksLnxSchedOut()+0x1f: call to {dynamic}() with UACCESS enabled
/tmp/vbox.0/vboxdrv/combined-os-specific.o: warning: objtool: rtThreadCtxHooksLnxSchedIn()+0x29: call to {dynamic}() with UACCESS enabled
/tmp/vbox.0/vboxdrv/combined-os-specific.o: warning: objtool: VBoxHost_RTR0MemKernelCopyTo()+0x15: redundant CLD
  LD [M]  /tmp/vbox.0/vboxdrv/vboxdrv.o
  MODPOST /tmp/vbox.0/vboxdrv/Module.symvers
  CC [M]  /tmp/vbox.0/vboxdrv/vboxdrv.mod.o
  LD [M]  /tmp/vbox.0/vboxdrv/vboxdrv.ko
make[2]: uscita dalla directory «/usr/src/linux-5.16.8»
make[1]: uscita dalla directory «/tmp/vbox.0/vboxdrv»
=== Building 'vboxnetflt' module ===
=== Building 'vboxnetadp' module ===
make[1]: ingresso nella directory «/tmp/vbox.0/vboxnetflt»
make[1]: ingresso nella directory «/tmp/vbox.0/vboxnetadp»
make V= CONFIG_MODULE_SIG= CONFIG_MODULE_SIG_ALL= -C /lib/modules/5.16.8-beny/build M=/tmp/vbox.0/vboxnetflt SRCROOT=/tmp/vbox.0/vboxnetflt -j6 modules
make V= CONFIG_MODULE_SIG= CONFIG_MODULE_SIG_ALL= -C /lib/modules/5.16.8-beny/build M=/tmp/vbox.0/vboxnetadp SRCROOT=/tmp/vbox.0/vboxnetadp -j6 modules
make[2]: ingresso nella directory «/tmp/vbox.0/vboxnetflt»
make[2]: ingresso nella directory «/tmp/vbox.0/vboxnetadp»
  CC [M]  /tmp/vbox.0/vboxnetflt/linux/VBoxNetFlt-linux.o
  CC [M]  /tmp/vbox.0/vboxnetflt/VBoxNetFlt.o
  CC [M]  /tmp/vbox.0/vboxnetflt/SUPR0IdcClient.o
  CC [M]  /tmp/vbox.0/vboxnetflt/SUPR0IdcClientComponent.o
  CC [M]  /tmp/vbox.0/vboxnetadp/linux/VBoxNetAdp-linux.o
  CC [M]  /tmp/vbox.0/vboxnetadp/VBoxNetAdp.o
  CC [M]  /tmp/vbox.0/vboxnetflt/linux/SUPR0IdcClient-linux.o
  LD [M]  /tmp/vbox.0/vboxnetadp/vboxnetadp.o
scripts/Makefile.modpost:134: attenzione: sovrascrittura del set di istruzioni per l'obiettivo «/tmp/vbox.0/vboxnetadp/Module.symvers»
scripts/Makefile.modpost:117: attenzione: ignorato il set di istruzioni obsoleto per l'obiettivo «/tmp/vbox.0/vboxnetadp/Module.symvers»
make[3]: Dipendenza circolare /tmp/vbox.0/vboxnetadp/Module.symvers <- /tmp/vbox.0/vboxnetadp/Module.symvers scartata.
  MODPOST /tmp/vbox.0/vboxnetadp/Module.symvers
  CC [M]  /tmp/vbox.0/vboxnetadp/vboxnetadp.mod.o
  LD [M]  /tmp/vbox.0/vboxnetadp/vboxnetadp.ko
make[1]: uscita dalla directory «/tmp/vbox.0/vboxnetadp»
  LD [M]  /tmp/vbox.0/vboxnetflt/vboxnetflt.o
scripts/Makefile.modpost:134: attenzione: sovrascrittura del set di istruzioni per l'obiettivo «/tmp/vbox.0/vboxnetflt/Module.symvers»
scripts/Makefile.modpost:117: attenzione: ignorato il set di istruzioni obsoleto per l'obiettivo «/tmp/vbox.0/vboxnetflt/Module.symvers»
make[3]: Dipendenza circolare /tmp/vbox.0/vboxnetflt/Module.symvers <- /tmp/vbox.0/vboxnetflt/Module.symvers scartata.
  MODPOST /tmp/vbox.0/vboxnetflt/Module.symvers
  CC [M]  /tmp/vbox.0/vboxnetflt/vboxnetflt.mod.o
  LD [M]  /tmp/vbox.0/vboxnetflt/vboxnetflt.ko
make[1]: uscita dalla directory «/tmp/vbox.0/vboxnetflt»
ba
Rama
Desktop: KDE 5.23
Messaggio da Rama »
credo di sì, comunque lanciato il tuo comando ottengo vari Warning e poi
fatal error: linux/smp_lock.h: File o directory non esistente
cerco nel web;
erio
Kernel: 3.0.7
Messaggio da erio »
se istalli virtualbox da .run ti crea una directory link in /usr/src entri nella directory e fai partire lo script che c'e' e se hai il sorgente del kernel dovrebbe farti i moduli che ti servono per usarlo.
Rama
Desktop: KDE 5.23
Messaggio da Rama »
lo so;
a forza di smanacciare ho ottenuto qualcosa, con modprobe carico vboxdrv, vboxnetflt e vboxnetadp, ma
modprobe vboxpci
modprobe: FATAL: Module vboxpci not found in directory /lib/modules/5.15.19
e
bash-5.1$ virtualbox
(process:24898): GLib-GObject-WARNING **: 17:38:08.347: cannot register existing type 'NMAgentManagerError'
(process:24898): GLib-CRITICAL **: 17:38:08.347: g_once_init_leave: assertion 'result != 0' failed
(process:24898): GLib-GObject-WARNING **: 17:38:08.347: cannot retrieve class for invalid (unclassed) type '<invalid>'
Errore di segmentazione
erio
Kernel: 3.0.7
Messaggio da erio »
ma hai la directory misc in lib/modules/5-15-19
guarda se ti e' utile: https://www.linuxquestions.org/question ... 175690823/
Rama
Desktop: KDE 5.23
Messaggio da Rama »
sì, ci sono i tre moduli che si caricano ma non vboxpci;
in una discussione ho trovato questo:
vboxpci doesn't exist anymore on 6.1.x but the message was not yet updated.
erio
Kernel: 3.0.7
Messaggio da erio »
la mia versione di virtualbox e' questa VirtualBox-6.1.97-149824-Linux_amd64.run e il sistema slackware current, non ho questi errori ,vedi il link sembra che ci sia una soluzione
Rama
Desktop: KDE 5.23
Messaggio da Rama »
dove l'hai presa? nel sito Oracle non c'è;
erio
Kernel: 3.0.7
Messaggio da erio »
https://www.virtualbox.org/wiki/Testbuilds, le versioni ufficiali sulla current non andavano,se usi la current il kernel e' cambiato 5.16.8.
Rama
Desktop: KDE 5.23
Re: Virtualbox e EFI [RISOLTO]
Messaggio da Rama »
è andata, grazie;
ora posso giocare a Civilization 3: è l'unico motivo per cui virtualizzo XP;
Ultima modifica di Rama il ven 11 feb 2022, 17:19, modificato 1 volta in totale.
DarthSteve
Nome Cognome: Stefano
Slackware: --Current--
Kernel: 5.15..x
Messaggio da DarthSteve »
Io ho virtualizzato Windows 10 per giocare a Guild Wars 2.
--- The Jedi Code ---
There is no emotion; there is peace.
There is no ignorance; there is knowledge.
There is no passion; there is serenity.
There is no death; there is the Force
