Slackware-current..non compila più nulla?
6C33C
Nome Cognome: Giorgio
Slackware: 14.0 x86_64
Kernel: 3.9.7
Desktop: kde 4.10.4 ,razorqt
Re: Slackware-current..non compila più nulla?
Messaggioda 6C33C » ven ago 24, 2012 10:03
Meskalamdug ha scritto:Freepopsd
compiling lua-curl.c -> In file included from lua-curl.c:182:0:
curl_authopt.h:1:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:1:1: error: missing terminating " character
curl_authopt.h:2:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:2:1: error: missing terminating " character
curl_authopt.h:3:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:3:1: error: missing terminating " character
curl_authopt.h:4:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:4:1: error: missing terminating " character
curl_authopt.h:5:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:5:1: error: missing terminating " character
curl_authopt.h:6:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:6:1: error: missing terminating " character
curl_authopt.h:7:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:7:1: error: missing terminating " character
curl_authopt.h:8:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:8:1: error: missing terminating " character
curl_authopt.h:9:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:9:1: error: missing terminating " character
curl_authopt.h:10:1: warning: missing terminating " character [enabled by default]
curl_authopt.h:10:1: error: missing terminating " character
curl_authopt.h:19:1: warning: large integer implicitly truncated to unsigned type [-Woverflow]
curl_authopt.h:20:1: warning: large integer implicitly truncated to unsigned type [-Woverflow]
Come si può risolvere?
Prova dare una occhiata qui http://www.archlinux.it/forum/viewtopic.php?p=124224
Sembra lo stesso errore e hanno messo risolto....
PS: non l' ho provato
6C33C
Kernel: 3.9.7
Messaggioda 6C33C » ven ago 24, 2012 11:23
Ho fatto delle prove ma non sono riuscito a farlo compilare :(
Cacchio lo uso anch' io freepops...... :x
Edit:
Eppure facendo un accrocchio come questo come da post su arch linux
cd $PKGNAME-$VERSION
gzip -cd $CWD/$PKGNAME.diff.gz |patch -p1
chown -R root:root .
chmod -R u+w,go+r-w,a-s .
./configure.sh linux-slack
make all
cat $CDW/curl_authopt.h > $TMP/$PKGNAME-$VERSION/modules/src/luacurl/lua-curl-0.3.0/curl_authopt.h
make install DESTDIR=$PKG
mkdir -p $PKG/etc/rc.d
mkdir -p $PKG/etc/freepops
cp -a buildfactory/slackware/rc.freepops $PKG/etc/rc.d
cp -a buildfactory/slackware/freepops.conf $PKG/etc/freepops/freepops.conf.new
chmod 755 $PKG/etc/rc.d/rc.freepops
pur dando errore finisce e genera il pachettuccio :oops:
Meskalamdug
Messaggioda Meskalamdug » ven ago 31, 2012 23:24
A me con quella toppa non trova gli headers :(
du palle..
Kernel: 5.0.0-rc3
Messaggioda ponce » dom set 09, 2012 17:49
mesk, prova un po questo
http://ponce.cc/slackware/testing/freepops-testing/
ti ci vogliono lua, lua-curl e lua-filesystem installati (ed opzionalmente zenity e fltk).
il lua-curl che e' dentro freepops non funziona, allora sono passato ad usare i lua, lua-curl e lua-filesystem del sistema.
Meskalamdug
Messaggioda Meskalamdug » mar set 11, 2012 21:10
Grazie ponce.
